Forum: FPGA, VHDL & Verilog cordic sincos output usage
von Harsha G. (Company: panacea) (harshaep)
Hi all,
I m using cordic ip core in spartan 6 device,futher im getting the
correct outputs too, but facing problem in multiplying tat output to
some number( like pwm ontime).
For Example
Input: Pin(phase): 0001100100011110
Output: cos(theta):Xout: 0010110101000111
Output: Sin(theta):Yout: 0010110100111011
from above example,
Phase in = 45 degrees or 0.785 in radians in 2QN format.
Xout: 11591 in decimal format, 0.7071067 in 1QN format
Yout : 11579 in decimal format, 0.7071 in 1QN format
Now consider ,
I want to multiply 50 * Xout
     = 50 * 11591  is what im able to do,but actually i need to do this
= 50 * 0.7071067
Please can any one help me out!!!!
Thanks in Advance
von experto (Guest)
what is "xout" in your design?
von Martin (Guest)
Actually,
as long  as you do not have a floating point unit
instantiated, all you can do is integer arithmetics.
So, you do
 50 * 11591
and then right shift  the result to avoid overflow, keeping the number
of right shifts  in memory.
Thank u ,it helped a lot.But how to handle wit floating points?,is der
any keyword for it?.
von Martin (Guest)
look at opencores.org,  guess you get a floating
point unit  from there.
von Martin (Guest)
sorry: opencores.com
