Forum: FPGA, VHDL & Verilog Top module problems..
Author: John Mayer (215)
I generated a fifo buffer using IP core, and are now having problem
using it.
I made This is my top module
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity top is
    Port (
        Mclk:  in std_logic;
        LED : out  STD_LOGIC_VECTOR (5 downto 0);
        LEDf: out std_logic;
        LEDE: out std_logic;
           BTN : in  STD_LOGIC_VECTOR (3 downto 0);
           Switch : in  STD_LOGIC_VECTOR (7 downto 0));
end top;
architecture Behavioral of top is
Component FIFO IS
  PORT (
    clk : IN STD_LOGIC;
    rst : IN STD_LOGIC;
    din : IN STD_LOGIC_VECTOR(98 DOWNTO 0);
    wr_en : IN STD_LOGIC;
    rd_en : IN STD_LOGIC;
    dout : OUT STD_LOGIC_VECTOR(98 DOWNTO 0);
    full : OUT STD_LOGIC;
    empty : OUT STD_LOGIC
END component;
begin
process(Mclk)
begin
if rising_edge(mclk) then
  clk <= mclk;
  LEDf <= full;
  LEDe <= empty;
  wr_en<= BTN(0);
  rd_en<= BTN(1);
  rst <= BTN(2);
  din <= switch;
  dout <= LED;
end if;
end process;
end Behavioral;
why isn't this working, it isn't recognizing the input ports on my
fifo.. these are the error messages.
Line 59. Undefined symbol 'clk'.
Line 60. Undefined symbol 'full'.  Should it be: null?
Line 60. full: Undefined symbol (last report in this block)
Line 61. Undefined symbol 'empty'.
Line 61. empty: Undefined symbol (last report in this block)
Line 62. Undefined symbol 'wr_en'.
Line 63. Undefined symbol 'rd_en'.
Line 64. Undefined symbol 'rst'.
Line 65. Undefined symbol 'din'.  Should it be: in or min?
Line 66. Undefined symbol 'dout'.  Should it be: out?
Author: Clem (Guest)
It doesn't know any or your ports (not just your input).
You have to instantiate your FIFO.
Have a look at a easy port map example.
e.g.
https://www.doulos.com/knowhow/vhdl_designers_guid...
I am not quite sure on how i should instantiate a component?
isn't what iam doing with component in my arcitecture?
-- EDIT--
entity top is
    Port (
        Mclk:  in std_logic;
end top;
Component FIFO IS
  PORT (
    clk : IN STD_LOGIC;
    rst : IN STD_LOGIC;
END component;
begin
G1: FIFO Port map (clk <= mclk , LEDf <= full, LEDe <= empty, wr_en<= BTN(0), rd_en<= BTN(1),rst <= BTN(2),din <= switch,dout <= LED);
end Behavioral;
Errors:
Line 57. Undefined symbol 'clk'.
Line 57. clk: Undefined symbol (last report in this block)
Line 57. Undefined symbol 'full'.  Should it be: null?
Line 57. full: Undefined symbol (last report in this block)
Line 57. Undefined symbol 'empty'.
Line 57. empty: Undefined symbol (last report in this block)
Line 57. Undefined symbol 'wr_en'.
Line 57. wr_en: Undefined symbol (last report in this block)
Line 57. Undefined symbol 'rd_en'.
Line 57. rd_en: Undefined symbol (last report in this block)
Line 57. Undefined symbol 'rst'.
Line 57. rst: Undefined symbol (last report in this block)
Line 57. Undefined symbol 'din'.  Should it be: in or min?
Line 57. din: Undefined symbol (last report in this block)
Line 57. Undefined symbol 'dout'.  Should it be: out?
Line 57. dout: Undefined symbol (last report in this block)
Line 57. IN mode Formal clk of FIFO with no default value must be associated with an actual value.
: Edited by User
How does this fifo look like? Is there a entity "fifo"?
Not in my Top module, but i have a VHDL module called Fifo, which is
generated by using the IP core
The FIFO vhd file is attached.
  • [vhdl]VHDL code[/vhdl]
