Forum: Analog Circuits new parametric search engine for Analog IC - Feedback appreciated
Author: Alexander (Guest)
Hello,
we started a new parametric search engine for Analog IC. The service
should be a big time saver for engineers and technicians, who are
working daily with IC specifications, looking for IC replacements or
searching for new products.
Our goal is a platform with all manufacturers in a certain analog IC
segment plus a wide range of available parameters. At the moment we can
offer 50+ IC manufacturer, 6000+ IC and 40+ standard and unique
parameters.
This should solve the problem that either only one manufacturer could be
searched for products at a given manufacturers homepage. Or using
Distributors/Sample Warehouses with a good choice of manufacturers but
limited still to their line-card and a usually very narrow set of
parameters.
We started with popular product segments like DC/DC Converter, DC/DC LED
Driver, DC/DC Controller and Dataconverter A/D & D/A (beta phase).
Please take a look and test us - feedback is highly appreciated:
www.DCDCselector.com
We have lot's of expansions in our 2014 roadmap. A few highlights are:
- 'backward search'- show all products with same or better performance
than the selected one
- rank all products based on their total solution size - including
passive components
- Segment References (Shunt, Voltage, Current)
- Segment Li-Ion Battery Charger
and much more.
Many Thanks for your time and feedback.
best regards,
Alexander
Author: Bitflüsterer (Guest)
-1 useful
I don't like java for security reasons. Better luck next time with
server side sripts.
-1 useful
And then: ajax.googleapis.com - Worse, again for security reasons. ;-)
Thank you for your feedback. For the moment this is the database
architecture we chose to enable a quick product search - but we are
always open for ideas and improvements.
How would you implement it ?
-1 useful
You mean, if I would be under contract?
Author: paddy (Guest)
Missing the widely-used DC/DC converter NCP2401
Also missing the cypress PSoc controllers. They have DC/DC and
high-performace ADC build-in. They should - in some way - be mentioned
IMHO
Author: http://www.Green-Man-Malton.co.uk/ (Guest)
any haut number démarrage, ces pieds arbore à brin près certainement
incroyables vêtements wishes ayant l'apparence avec plusieurs manteaux.
Ce seront certainement ce meilleur costume outfit dress adapté dans le
but de nufactured multiples personnes à travers vos tenues flood leur
assortiment {pour|put|serve|fill|dump|add|strain|dans le but de|storage
containers .
http://www.Green-Man-Malton.co.uk/ http://www.Green-Man-Malton.co.uk/
Author: hmm (Guest)
php, javascript
Author: G-Ride (Guest)
Dear Alexander,
I am looking for an ADC with at least 14 bit accuracy on two
simultaniously converting differential channels (meaning 2x2=4 Channels,
2 ADCs). So let's see how my search goes on your website:
- Resolution: at least 14 bit resolution, I would be fine with 15 to 31
bit as well, how do I tell your selector?
- Channels: at least 4 but why not 5 to 256? How do I tell your
selector?
- Sample-Rate: Finally! A smaller/greater than option, you need that
everywhere!
- Differential: Where do I enter that?
- Two ADCs in one housing: Where do I enter that?
- Package: I want to use QFN in a certain size range. It would be nice,
if you could add a search function, where one could sort by the sizes of
a certain package type because in most parameter searches you can only
sort by smallest outline of all available packages, which is usually a
ball grid array. I you cannot handle a ball grid, you simply cannot use
the sort by outline function.
Sorry, but this parametric search is really no help yet. It just uses
the same (IMO crappy) parameters as the vendors and manufacturers but
doesn't even give you a greater/smaller-option and a
I-don't-care-option, which is a killer-argument against your website.
In my opinion, the perfect parametric search would be a wiki/openSource
kind of search engine. That way, not only you and the manufacturers but
also the millions of users could contribute to the search and add new
categories like "qfn-outline", "qfp-outline", "ballgrid-outline" or
whatever categorie you don't have in mind yet but the users actually
look for.
Regards and keep on developing!
Author: Alex (Guest)
Hi G-Ride,
Thank you for taking time and testing our parametric search engine. I
have great feedback for you, basically all of your suggestions will be
ready once we make it to version 1.0.
As you may have noticed the Data Converter Selector is still at an early
stage (beta 0.5) compared to other Selectors so lot's of updates are
scheduled over summer time.
updates till v.1.0. (most are already working in our test system)
- min/max or smaller/greater option for main parameters
- differential or single ended input
- number of  ADC per product/package
- uni-polar/bi-polar/true-bipolar input
- search by input range like 0 to 5V or -5 to 5V
- package data like number of pins and size in mm²
- sort function across all products for smallest package size and/or by
package family
We spend a lot of time in adding products and parameters. We don't use
'crappy feeds' at all. Please give us a little time and wait for v.1.0.
All search functions will be ready and of similar great quality as the
other Power Management or LED Driver Selectors already are.
Again thank you for your feedback. I encourage also other user to do so,
so we can improve further.
Alex.
Small update, we activated 2 new helpful functions:
- side by side product comparison for up to 5 products (via 'i' pages)
- pre-selection for preferred suppler across all Selectors (via
homepage)
Our first (and simple) video tutorials for those functions can be found
here: http://www.dcdcselector.com/en/tutorials
Thanks,
Alex.
