Forum: FPGA, VHDL & Verilog testbench in vhdl-ams
Author: sebgimi (Guest)
Hi everybody,
I want to create a testbench for a vhdl-ams code but I can't fix the
errors in compilation.
Below, I show you how I usually write a component and his correspondant
testbench in vhdl:
CODE:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity compteur is
  generic (N : integer:= 8);
  port(clk  : in std_logic;
       reset: in std_logic;
       load : in std_logic;
       data : in std_logic_vector (N-1 downto 0);
       flag : out bit;
       Q    : out std_logic_vector (N-1 downto 0));
end compteur;
architecture archi of compteur is
signal Qtmp: std_logic_vector (N-1 downto 0);
constant value : std_logic_vector := "00000111";
begin
  process (clk, reset)
  begin
    if clk 'event and clk = '1' then
      if reset = '0' then
        Qtmp <= (others => '0');
      elsif load ='1' then Qtmp <= data;
      else Qtmp <= Qtmp + 1;
      end if;
    end if;
  end process;
Q <= Qtmp;
flag <= '1' when Qtmp = value else '0';
end archi;
TESTBENCH:
Library IEEE;
Use IEEE.std_logic_1164.all;
library work;
use work.all;
entity compteur_tb is
end compteur_tb;
architecture archi of compteur_tb is
component compteur
       flag : out bit;
end component;
signal clk  : std_logic;
signal reset: std_logic;
signal load : std_logic;
signal data : std_logic_vector (7 downto 0);
signal flag : bit;
signal Q    : std_logic_vector (7 downto 0);
constant T : time := 50 ns;
begin
  uut: compteur port map (clk => clk, reset => reset, load => load, data => data, flag => flag, Q => Q);
  clk_proc: process
  begin
    loop
      clk <= '0';
       wait for T/2;
       clk <= '1';
       wait for T/2;
    end loop;
  end process clk_proc;
  stimuli: process
  begin
    reset <= '0';
    load <= '1';
    data <= "00000011";
    wait for 40 ns;
    reset <= '1';
    load <= '1';
    wait for 100 ns;
    reset <= '1';
    load <= '0';
    wait for 200 ns;
    reset <= '1';
    load <= '0';
    wait for 100 ns;
    reset <= '1';
    load <= '0';
    wait for 200 ns;
    reset <= '0';
    load <= '0';
    wait for 150 ns;
    assert false report "NONE. End of simulation." severity
    failure;
    wait for 100 us;
  end process stimuli;
end archi;
Now in vhdl-ams:
library ieee;
use ieee.electrical_systems.all;
use ieee.std_logic_1164.all;
use ieee.math_real.all;
entity comparateur is
  generic (level : real := 2.5;   -- seuil
     vcc   : real := 5.0;   -- etat haut sortie
     gnd   : real := 0.0);  -- etat bas sortie
  port(terminal e: electrical;  -- entree analogique
             signal   s: out real); -- sortie numerique
end comparateur;
architecture archi of comparateur is
quantity v across e;       -- across quantity to ground
begin
     s <= vcc when v'Above(level) -- v > level
     else gnd;                    -- v < level
end archi;
library ieee;
library st_lib;
use st_lib.all;
entity comparateur_tb is
end entity comparateur_tb;
architecture archi of comparateur_tb is
component comparateur
end component;
signal e : electrical;
signal s: real;
constant T : time := 10 ns;
begin
  uut: comparateur port map (e => e, s => s);
  stimuli: process
  begin
    loop
      e <= 5.0;
       wait for T/2;
       e <= 0.0;
       wait for T/2;
    end loop;
    failure;
    wait for 100 us;
end archi;
And when I compile testbench I'm getting these errors:
ncvhdl -work st_lib -ams -message ../sources/comparateur_ent.
vhdl ../sources/comparateur_arch.vhdl ../sources/comparateur_tb.vhdl
ncvhdl: 13.10-s013: (c) Copyright 1995-2013 Cadence Design Systems, Inc.
../sources/comparateur_ent.vhdl:
        errors: 0, warnings: 0
../sources/comparateur_arch.vhdl:
../sources/comparateur_tb.vhdl:
ncvhdl_p: *E,EXPTYM (../sources/comparateur_tb.vhdl,24|20): type mark
expected [
4.2].
ncvhdl_p: *E,IDENTU (../sources/comparateur_tb.vhdl,31|33): identifier
(E) is no
t declared [10.3].
                        e <= 5.0;
ncvhdl_p: *E,IDENTU (../sources/comparateur_tb.vhdl,37|3): identifier
(E) is not
 declared [10.3].
                        e <= 0.0;
ncvhdl_p: *E,IDENTU (../sources/comparateur_tb.vhdl,39|4): identifier
(E) is not
 declared [10.3].
        errors: 4, warnings: 0
Do you know why and how to fix it ?
Even if this is no comparaison between compteur (counter) and
comparateur (comparator), I show you that to see how I do usually.
Thanks in advance!
  • [vhdl]VHDL code[/vhdl]
