Forum: FPGA, VHDL & Verilog Tri state buffer
Author: vhdl newbie (Company: none) (pranoy)
library ieee;
use ieee.std_logic_1164.all;
entity tristate_buffer is
port (enable: in std_logic;
d_in: in std_logic_vector ( 7 downto 0 ) ;
d_out: out std_logic_vector (7 downto 0 )) ;
end tristate_buffer;
architecture behavioral of tristate_buffer is
begin
process (enable,d_in)
begin
if (enable = 1) then
d_out <= d_in;
else
d_out <= (zzzzzzzz);
end if;
end process;
end behavioral;
what is the error in this program?
i get the following errors when i compile it in modelsim
tri_state_buffer.vhd(14): near "?": syntax error
tri_state_buffer.vhd(17): near "?": syntax error
Author: Schlumpf (Guest)
Vectors: "ZZZZZZ" and not `ZZZZZZ´
Single Signals: '1' and not `1´
Thanks
library ieee;
begin
begin
if (enable = '1') then
d_out <= d_in;
else
d_out <= ("zzzzzzzz");
end if;
end process;
end behavioral;
now the program is like this.
but new errors are coming like
tri_state_buffer.vhd(19): String literal has a character 'z' not in the
enumeration type ieee.std_logic_1164.std_logic.
tri_state_buffer.vhd(22): VHDL Compiler exiting
pls help
THANKS
Got it.
The high impedence should be Z instead of z. :)
  • [vhdl]VHDL code[/vhdl]
