Forum: FPGA, VHDL & Verilog fifo generated using core generator is not working fine and i need some one to help me with a soluti
Author: SANJAY NAMBIAR (Company: BEL) (sanjay)
i am using  xylinx v 13.1 and using this i have written an fsm to
interact between processor and fifo for a FIFO generated using core
generator. the problem which i am facing is that the data will write and
den the write data count of fifo will also rise but this happens only
after 3 write write cylces. because of this am not able to obtain the
data which i have written when i am enabling the read signal of the fifo
. the write data count which should remain constant is also decrementing
when i am reading the data. but the data read is only the second data
written at this case. the problem which i found was that fifo full which
was high inititally is going low only after 2 write clocks and the fifo
empty is going low only after 3 write clocks. when i noticed this
problem i added another state  to solve this issue but then when i
enable read signal of fifo it is only reading the first data.can any one
help me with a soulution?
Author: hardware guru (Guest)
hm, fifo control is not a big thing, mostly counting sime numbers and
gatin at the right points of time
you seem to have difficulties with a time line issue caused by the
latency most probably. did you write down the time line for your code?
usually documenting this in detail prior start shows the issue before a
false implementation is began
from here it is difficult so guess, where there might be a problem,
since we do not have a clear image what you already did and what you
really intend
  • [vhdl]VHDL code[/vhdl]
