Forum: µC & Digital Electronics c++ object of an output (LED)
Author: micro u. (Guest)
hi
im looking for some simple solution for my output class led.
momentary, im buildung my own litte library for simple avr applications
for beginner.
first class will be used to set up an led object like this:
#ifndef CLED_H_
#define CLED_H_
class CLED
    short pL, pN;
    public:
    //constructor
    LED(){
    //methods
    void ini(){
    void toggle(){
    // do something
    void turnOn(){
                // do something
    void turnOff(){
                // do something
}; //CLED
#endif /* CLED_H_ */
main.cpp
DDRC |=  ((1 << PC0);
im looking for a solution, for the constructor or an ini method,
whatever works.
when you generate the object, you add some paramaters (eq.: B 3 (PortB
Pin3)) and then, when i finally control the object, it knows itself,
where to rout the signal.
eg:
generate the object:
CLED ledRed("B", 3);
control it:
ledRed.toggle();
Author: Tom (Guest)
Andreas Ferber did some template magic which does approx. what you are
planning to do. As a bonus the compiler can remove all of the overhead
of the class: Beitrag "IO-Register als Template-Parameter"
