Forum: ARM programming with GCC/GNU tools Jump tables for gcc-arm cross compiler
von Farhan (Guest)
I would really appreciate if some one could tell me how to initiate jump
tables for gnu arm assembler. I have written the below code at the end
of my .s file. I have tried all sorts of things (using .align, .p2align,
.long etc) but i can't get the _input_case_table to get the 4 byte
addresses for str_help and str_sum. Assuming input starts at 0x100e4
memory in the debugger, I have reproduced the 32 byte memory location
following it.
 * --- Data follows ---
/* Let's pretend this command was entered by the user */
input:  .ascii "sum"
  .byte 0, 0, 0, 0, 0
str_help:
  .ascii "HELP"
  .byte 0, 0, 0, 0
str_sum:
  .ascii "SUM"
  .byte 0, 0, 0
/* Recognized commands */
_input_case_table:
  .word  str_sum
  .word  str_help
---------_GDB_MEMORY_OUTPUT-------------------
Attached in file
I am using the gcc-4.6-linux-arm-gnueabi compiler tool chain. Using
gdb-multiarch with architecture set to armv4.
I am still new to this so any guidance would be much appreciated.
To reiterate my question, im tyring to compile code for armv4 32bit
processor mode. I know how alignment and 'DCD' statements work but for
Keil Development tools only. I would really appreciate if some one could
point me how to do the using the GNU assembler.
von Kindergärtner (Guest)
Maybe try:
_input_case_table:
  .word  =str_sum
  .word  =str_help
von Marc P. (marcvonwindscooting)
Did you find out?
Surprisingly, I use your style since years, successfully.
Most recently for LPC800:
.text
.thumb
vectorTable:
        initialSP:      .word   0
        initialPC:      .word   _start+1
.global _start
_start:
The only difference is the presence of the labels.
