Forum: Analog Circuits An easier way to do circuits
von Shawn (Guest)
Good afternoon,
Over the past several months we have been developing what we call Simple
Circuits.  They are single function development boards that can be used
as building blocks to create circuits.
Best part about it is that we just launched a Kickstarter today!! If you
have a minute please check it out and give us your feedback! Really
looking forward to it.
http://www.kickstarter.com/projects/1661971884/analog-is-easier-with-simplecircuits
Thanks,
Shawn
von troll (Guest)
Is there a particular reason for loading all the images via https?
von Kan a. (Company: Basta) (kanasta)
You really think the world needs analog arduinos?
von Shawn (Guest)
Even if you have an Arduino... you can't do everything with it...
external analog components are still needed and this is where these can
be very helpful.
von Klaus (Guest)
why should I buy this? A simple breadboard is more flexible and if I
have SMD components I can buy very cheap adapter PCBs from ebay.
von Shawn (Guest)
Kalus,
You are right.
We are just trying to offer a kit to people that offers everything they
may need for their projects.  The idea is we want them to use a bunch of
our Simple Circuits and when they need a push button for instance, we
will have that for them which can be easily integrated into their
project rather than an "off the shelf" button.
Also even if you have an adapter board, there are still components that
need to be added.  ie you cant just put an OP AMP IC down on a breakout
board and expect it work correctly...  We have already done that work
for you so it is simple to integrate into you projects.
