Forum: µC & Digital Electronics Microcontroller (AT91SAM7A3) only crashes when not running with gdb
Author: Jan Bolting (Guest)
Hey guys,
I am debugging some code on a AT91SAM7A3 that shows an odd behaviour: as
long as it is connected by JTAG and run via gdb, everything works fine.
If I do a power-on reset without running gdb, it boots up fine, but I
can make it crash by sending some characters on a USART port (what works
fine while debugging). The crash is 100% repeatable.
That puts me in a bad position because it's kind of hard to hunt down a
bug that only shows up when the debugger is not connected.
It's a bare-metal system, the code is C and C++, the compiler is
gcc/g++.
Has anyone experienced anything like this before?
best regards,
Jan
Author: amateur (Guest)
Have a look at your asynchronous buffer management?
Maybe your debug environment slows the system down a little so that no
overflow will occur.
Author: Uwe Bonnes (Guest)
Another thing is to check is if the program uses semihosting.
Thanks for the hints,
I will check both possibilities and post it here once I figured out the
problem.
regards
Jan
