Forum: Analog Circuits NAND,NOR-Logic
von Alexander (Guest)
Hi!
Can anyone explain to me how do i convert to NAND and NOR-logic?
von Autor (Guest)
von Stephan S (Guest)
every gate can be built using NANDs.
von Mike (Guest)
XOR dos't really help, as it can be composed of 4 NANDs
von Davis (Guest)
AND truth table
A B  Q
0 0  0
0 1  0
1 0  0
1 1  1
NAND truth table
A B  Q
0 0  1
0 1  1
1 0  1
1 1  0
Take one NAND for the inputs A & B and another NAND to negate the output
of the first to build an AND gate.
NAND      NAND
A-|\    .-|\
  | )o--| | )o--- Q
B-|/    .-|/
After some time of thinking and researching this is what i came up
with!please comment if i did it right!
von 6A66 (Guest)
Hello Alexander,
you do not end up with a correct solution by just painting inversion
bubbles in between.
One hint already was given: Try to make up a truth table for the inputs
(this is in total 6 inputs and quite complex).
The next hint was given to use a conventional de morgan notation and to
convert this.
The third is:
You'll have a look onto the schematic. It consist of two blocks: the
uppermost left block that consists of an and-or function with the lower
"and" function subsituted. And a second and_or function on the right.
There are two approaches to solve that:
a) You look up http://en.wikibooks.org/wiki/Digital_Circuits/NAND_Logic.
You'll find out that a "and" ia a "nand" with following inversion.
You'll find out that an "or" is a "nand" with previous inversion.
You sketch them together and you'll find out that there are two
inversions sequentially which can be eliminated. This will lead you to
b)
b) You'll find in your literature that a "and-or" combination can
substuted by an "nand-nand" conbination without any modification.
Now you have to convert the both blocks (uppermost left and right)
separately and you will come up with the solution.
Any questions? Feel free.
rgds
