Forum: ARM programming with GCC/GNU tools ARM NEON Assembly Programming in Android
von vigneshwaran v. (vigneshv)
Hi All,
I am new to ARM as well as ARM NEON, i would like to code few of my c++
module to arm neon assembly module in android environment. I am using
GNU assembler. I have faced problem in calling equivalent assembly
module for my c++ module in my workspace. I have faced the following
problems.
     1. When i enable both the c++ and assembly function, the compiler
build the project successfully instead of showing error as "multiple
definition for the function", and shows error in assembly program if any
syntax error in the instruction.
     2. But when i enable assembly function alone and disable the c++
module, i got the error as "undefined reference" to the function, though
i gave ".global function name" at the starting of the program.
     I don't know to make any changes in make file. My make file details
as follows
LOCAL_PATH := $(call my-dir)
include $(CLEAR_VARS)
LOCAL_MODULE := ColorConv
#LOCAL_ARM_MODE := arm
LOCAL_ARM_NEON := true # remove this if you want armv5 mode
LOCAL_SRC_FILES :=\
LOCAL_CPP_EXTENSION := .cpp
LOCAL_CFLAGS := -mfpu=neon -DANDROID_NDK -fPIC -Wall -fexceptions
-ffloat-store -Wuninitialized -g  -I hevc/hdr/
#ASFLAGS := -x assembler-with-cpp
#-DHAVE_NEON=1 -std=c99 -pedantic -v
LOCAL_C_INCLUDES :=$(LOCAL_PATH)/hevc/hdr/
LOCAL_LDLIBS := -llog -ljnigraphics -lGLESv1_CM -ldl -lz
include $(BUILD_SHARED_LIBRARY)
Please, guide me to solve this problem.
Thanks in Advance,
Vigneshwaran V
