Forum: FPGA, VHDL & Verilog vhdl accessing std_logic_vector
Author: Barade Barade (barade)
the following example won't be compiled with gvhdl:
library ieee;
use ieee.std_logic_1164.all;
entity DemultiplexerEntity is
  port(E: in std_logic;
    SEL: in std_logic_vector(1 downto 0);
    Y: out std_logic_vector(3 downto 0)
end DemultiplexerEntity;
architecture DemultiplexerArchitectureSelektiv of DemultiplexerEntity is
  signal INDEX: integer;
begin
  with SEL select
    INDEX <= 0 when "00",
      1 when "01",
      2 when "10",
      3 when "11",
      0 when others;
  Y <= "0000"; -- clear
-- DOESNT' WORK
  --Y(INDEX) <= E;
end DemultiplexerArchitectureSelektiv;
It says:
c++: test.cc: In member function ‘virtual bool L4work_E19demultiplexerentity_A33demultiplexerarchitectureselektiv_P4_7pn::execute()’:
c++: test.cc:337:144: error: ‘L4work_E19demultiplexerentity_A33demultiplexerarchitectureselektiv_S5index’ was not declared in this scope
How can I access the output logic vector properly?
-- DOESNT' WORK
  --Y(INDEX) <= E;
What doesn't work?
Does it not work when you uncomment the second assignment?
So, when you try at "first" clearing the vector and "afterwards" setting
1 output bit?
What do you want to do at all?
The error below occurs when I uncomment the section.
I just want to make sure that all other output bits are 0. I want to
determine the index of the output bit position and therefore write one
single bit into the vector at position INDEX.
You cannot do this (assigning two values to one signal) with a
concurrent statement! Use a process instead:
  process (E, INDEX) begin
    Y <= "0000";      -- default assignment
    Y(INDEX) <= E;    -- "last" assignment "wins"
  end process;
A simulator should be able to handle this conflict. It must result in
"X" values, but all in all the concurrent style code is able to be
compiled...
  • [vhdl]VHDL code[/vhdl]
