Forum: FPGA, VHDL & Verilog Multiple assignments in verilog
Author: nelson george (Company: student) (together)
I have written the following verilog codes.....The first one will
execute in one clock cycle......But due to multiple assignments of
variable ,the second code is not executing in one clock cycle.....Can
anyone suggest any method so that the second code also will execute
fully in one clock cycle????
PLZ HELP
//pgrm 1
always @(posedge clk)
begin
s<=8'h01;
s_rot <= 8'h01;
s_2<= 8'h03;
s_out1<= 8'h01;
s_out2<=8'h01;
end
//pgrm 2
begin
s<=(DATA_WIDTH-m);
s_rot <= s<<1;
s_2<=s+8'h03;
s_out1<=s_rot+8'h01;
s_out2<=s_rot+s_2;
end
Author: hiall (Guest)
blocking assignments
Author: Ale (Guest)
I'd suggest you get a good learning book about Verilog, and read it at
least 3 times. The concepts are not difficult but they are different
from C programming.
You know '<=' is an unblocking assignment, right ? Good:
On the rising edge of the clock all registers will get updated with the
current values that are on the right.
The values in the first example are fixed, then all registers get those
values.
On the second example:
First rising edge
1. s_rot gets s shifted 1 to the left
2. s_2 gets s plus 3
3. s_out gets the current value of s (not yet shifted) plus 1
4. s_out2 gets the current value of s plus whatever value s_2 has
Second rising edge
The same as above... now s_out contains the shifted s plus 1...
Author: Ale (Guest)
Get icarus verilog and Gtkwave and simulate everything :)
Author: Ale (Guest)
Ops, I meant for points 3 & 4 s_rot instead of s.
  • [vhdl]VHDL code[/vhdl]
