Forum: FPGA, VHDL & Verilog error in place and route step
Author: slalas dafvj (Company: dwygfdyuf) (sarmadff)
help me please
in my design this error appear in place and route step
tha target device is spartan 3e and the ise is ise14.1
error: Place:120 - There were not enough sites to place all selected
components.
Some of these failures can be circumvented by using an alternate
algorithm (though it may take longer run time). If
you would like to enable this algorithm please set the environment
variable XIL_PAR_ENABLE_LEGALIZER to 1 and try
again
and the utilization summary is attached
why this error occurs and how can overcome this error please?
Author: Duke Scarring (Guest)
In your report no ressource is used more than 100%.
Try to "Cleanup Project Files" and generate the report again.
Duke
I'm wondering about the high number of latches and clocks in that
design...
Which one?
thank you for your answer
my device is spartan3e xc3s500e-4fg320
how can reduce the number of latch and number of clk?
Just don't describe latches in your design.
And therefore you must first be able to recognize latches in your
design: latches are level sensitive "flipflops".
BTW: is it a VHDL or a Verilog design?
> and number of clk?
Answer this question first: how many clocks do you need at all?
If you don't know an answer, then the correct answer may be: ONE!
my design written in VHDL code
i need one clock for all design how can archive this?
Usually this is the clock from a xtal-oscillator in the range of
30..100MHz. And these descritpion result in a clocked flipflop in a VHDL
design:
 if clk50MHz'event and  clk50MHz='1' then
 if rising_edge(clk50MHz) then
 if falling_edge(clk50MHz) then
 wait until clk50MHz'event and  clk50MHz='1';
 wait until rising_edge(clk50MHz);
 wait until falling_edge(clk50MHz);
So whereever a similar construct appears, there must be used the same
signal. Then you have only one clock source over the whole FPGA.
i use
if(clk'event and clk='1') then
end if;
for 18 times
but the BUFGMUX is 18 from 24 why??
> for 18 times
Is clk always the same signal?
Duke
yes is same signal for all design
Can you show us an example of your code?
Duke
  • [vhdl]VHDL code[/vhdl]
