Forum: µC & Digital Electronics SPI not able to be switched off (MOSI - PIN ) @ATmega1284p
Author: Daniel (Guest)
Hello Forum,
I'm using the SPI of ATMega 1284(p) and need for creating a longer pulse
a short switchoff of the intended SPI function.
The SPI is configured to be a master and works.
Unfortunately the SPI can't realy switched off, because i can't drive
the MOSI (Pin B5) to Grounds.
My basic idea was: Get all registers back to initial value!
This don't work(!):
// Switchoff SPI Interface (to abtain control of lines)
      PRR0 |= (1<<PRSPI); // Disconnect Clock
      SPCR = 0;  // Init Value
      SPSR = 0;
If i  do not apply the commented line "Disconnect Clock" and leave it
complet off like this:
      SPSR = 0;
It works !
I don't find any hint in spec for switching off SPI !
Datasheet regarding  PRSPI:
Bit 2 - PRSPI: Power Reduction Serial Peripheral Interface
Writing a logic one to this bit shuts down the Serial Peripheral
Interface by stopping the clock to the module.
When waking up the SPI again, the SPI should be re initialized
to ensure proper operation.
I assume that the ATMEL need the clock to switch of (and load) the
registers!
Did anybody out there share the same experiance ?
(Finding and fixing time appros 4 hours ! **grr**)
Regards Daniel
