Forum: FPGA, VHDL & Verilog VHDL - Johnson Counter - Simulation Output with 'U's
von burami s. (Company: none) (bur85x)
Hello all. I've been coding a Johnson Counter like the following:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity johnson is
generic (n : natural := 4);
port (clk, enable : in std_logic;
      count : out std_logic_vector (n-1 downto 0));
end johnson;
architecture behavioural of johnson is
signal reg_john, nxt_john : std_logic_vector (n-1 downto 0);
begin
   process (clk)
   begin
      if (clk'event and clk='1') then
         if (enable='1') then
            reg_john<=nxt_john;
         end if;
      end if;
   end process;
   process (reg_john)
   begin
      nxt_john<=reg_john (n-2 downto 0) & not reg_john (n-1);
   end process;
   count<=reg_john;
end behavioural;
The synthetization was OK. The thing is when I tried to simulate the
code, all the outputs from the count were having the letter 'U'.
Please, take a look at the attached screenshot.
Note that "habilitacion" = "enable" and "cuenta" = "count".
What are those 'U's? How can I fix the simulation in order to work?
Thanks a lot.
von Klaus (Guest)
'U'  is the value for "uninitialized". Think about, at which value your
counter starts. You can't determine is from the source code? So the
simulator can't either! ;-)
For the synthesiser, there is no value like 'U', only '0' and '1'. So it
has to choose a value. Most likely it will use 0.
Thanks Klaus, and I've also realized that the Xilinx Simulator has two
kinds of options to simulate: "Behavioural Simulation" and "Post-Route
Simulation", so I tried the last one in this case and it seemed to work.
Both types of simulation will "work", if you just initialize the
counters signal with  (others =>'0')
Don't work around some problem! Try to understand what's going on...
Thank you very much, Lothar, you're right.
I'm going to try it and see what happens. :)
Here's the fixed Johnson Counter.
