Forum: ARM programming with GCC/GNU tools ARM: Beginners questions about startup and Linker
von sNOOBy (Guest)
Hello,
I recently started programming an ADuC7026 Microcontroller which has a
ARM7TDMI core.
I managed to write a code that blinks a LED (attached), however even
though the code works, there are some issues that I don't understand.
First a question regarding the startup code: At the beginning of the
startup code I try to set up the vector table whith a Branch to the
actual startup routine (_start) at the first address, which will later
be linked to 0x0. However I discovered, that if I modify this line to
say
reset:  B  reset
the code will still work! Shouldn't this modification result in the MCU
never reaching the rest of the code?
The second question is about the Linker-script: The Flash begins at
address 0x80000 which after reset is equivalent with address 0x0? So it
shouldn't make a difference if the "." variable is set to 0x0 or 0x80000
before the .text section? What I found was, that this does indeed not
make a difference. However I can actually give the "." any value I want
and it will still work! Also exchanging the placement order of the
subsections to eg:
* (exception_vectors);
* (.text .text.*);
doesn't have any impact!
I feel like any of the described modifications should prove fatal for my
code.
I would be really glad if someone could explain where I have gone wrong.
Also, as a beginner, I appreciate any other comments and advice on the
code.
Thanks for your help already!
Greetings
