Forum: ARM programming with GCC/GNU tools Makefile problem
von Riou Yannick (Guest)
HI, I'm using Yagarto compiler on a mac with the netbean IDE, I've a
LPCxpresso 1769 and I don't find a working makefile and startup script
to compile an .hex file to upload on my board (with a ftdi in uart)...
Does someone have these files or have useful links that help to write
these files ??
Thans for your help.
Madz
von Martin Thomas (Guest)
Maybe the makefile from my project can server as template:
http://siwawi.bauing.uni-kl.de/avr_projects/arm_projects/arm_memcards/index.html#chanfat_lpc_cm3
. In this project there is also some startup-code and a linker-script.
The project is rather old. Up-to-date startup-code should be available
in the CMSIS-Package for this controller from nxp.com. To "upload the
hex-file" you may use the software lpc21isp (
http://lpc21isp.sourceforge.net/ )
