Forum: FPGA, VHDL & Verilog Assigning constants on ports during component instantiation
Author: Mayank Srivastava (maysri)
Can we assign constant or values directly to ports during component
instantiation.
Code Snippet  :
fir_1  : fir_d
         port map (
           clk   => clk,
           ctl_R   => "0110111000000001", -- input port of 16 bits
If we assign, will it be trimmed during synthesis? Any other method to
pass values to ports.
Thanks
Author: user (Guest)
When you apply constant values to a port, then the synthesis tool will
optimize it (if enabled). FPGA synthesis tools have optimization enabled
by default, ASIC synhtesis tools not.
It is also possible to use "generic" and "generic map"
The constraint with the above code is that, I have to pass values
through ports only. To pass values to ports, I tried another method
using ROM.
Code Snippet  :
entity app is
port (
  clk    : in std_logic;
  rst    : in std_logic;
  ce    : in std_logic;
  a0    : out std_logic_vector(15 downto 0);
  a1    : out std_logic_vector(15 downto 0)
end app;
architecture Behavioral of app is
component counter is
  generic ( width  : integer  := 10;
      limit  : integer  := 512
  port(clk, clr, ce : in std_logic;
       q : out std_logic_vector((width-1) downto 0);
       q_valid  : out std_logic);
end component;
component rom_file is
  generic (
    limit   : integer    := 512;
    FileName : string    := ""
  port (
    clka  : in std_logic;
    ena  : in std_logic;
    addra  : in std_logic_vector((width-1) downto 0);
    doa  : out std_logic_vector(15 downto 0)
end component rom_file;
component reg is
  generic (
    Width  : integer  := 16 -- port width
  port (
    clk  : in std_logic;
    ce  : in std_logic;
    rst  : in std_logic;
    d  : in std_logic_vector((Width-1) downto 0);
    q  : out std_logic_vector((Width-1) downto 0)
end component reg;
signal s_addr    : std_logic_vector(3 downto 0);
signal s_data    : std_logic_vector(15 downto 0);
type reg_array is array (0 to 9) of std_logic_vector(15 downto 0);
signal reg_data  : reg_array;
begin
cntr1  : counter
  generic map (
    width    => 4,
    limit    => 10
  port map (
    clk    => clk,
    clr    => rst,
    ce    => ce,
    q    => s_addr,
    q_valid          => open
rom_fir  : rom_file
  generic map (
    width    => 4,
    limit    => 10,
    FileName  => "./rom/fir_p.dat"
  port map (
    clka    => clk,
    ena    => '1',
    addra    => s_addr,
    doa    => s_data
--generate_data_out : for i in 0 to 9 generate
process(clk)
begin
  if(clk'event and clk = '1') then
    for i in 0 to 9 loop
      reg_data(i) <= s_data;
    end loop;
  end if;
end process;
--end generate generate_data_out;
reg_val1  : reg
  generic map (
    width    => 16
  port map (
    clk    => clk,
    rst    => rst,
    ce    => ce,
    d          => reg_data (0),
    q          => a0
reg_val2  : reg
  generic map (
    width    => 16
  port map (
    clk    => clk,
    rst    => rst,
    ce          => ce,
    d    => reg_data (1),
    q    => a1
end behavioral;
In this method, I'm trying to store each value of ROM into separate
registers. Suppose ROM contains {0001, 00AD, 987B,...}, then reg 1
should contain the value 0001 only, reg 2 should contain 00AD only and
so on.
For counter and ROM, Xilinx HDL codes are used. In entity app, only two
output ports are mentioned for simplicity.
But the above code is storing all the values of ROM in each registers.
Kindly guide me.
Thanks
  • [vhdl]VHDL code[/vhdl]
