Forum: µC & Digital Electronics division with microcontrollers
Author: Natascha (Guest)
I've been working with an AT32UC3C1512C microcontroller using the ADC to
read four values from a PSD. I then want to apply an equation to the
four digital outputs to obtain a position, but it involves dividing some
of these outputs. Here I have run into a bit of a wall. Just using plain
division (/) won't work because it doesn't give me the correct value
when I pass it through the DAC and read it out. Therefore I tried to
look at some digital division algorithms, but that would involve the use
of assembly, and I'm not sure how to integrate this with a 32 bit
microcontroller. I found an application note from Atmel on how to
combine assembler and C, but I can't find the example code which the
whole note is based on, and so it doesn't help at all. Does anyone know
how to get around this?
Author: Uwe Bonnes (Guest)
Maybe it is easier to multiply by 1/X than to divide by X...
Otherwise if the division doesn't work, your setup may be broken...
Author: Eumel (Guest)
Are you using float or int numbers?
