Forum: ARM programming with GCC/GNU tools ARM Programming In Ubuntu
Author: Thenappan KLS (klsthenappan)
Hi everyone,
      On my own interest I am doing ARM based projects(primarily
ARM7TDMI). Right now I am using KEIL IDE in Windows. I need to move to
Linux based environment. I donot know how to start this. I installed
Ubuntu Desktop Environment in my Laptop. Please guide me to start on
this.
Thanks
Author: MacLyon (Guest)
Look at this link :
http://www.atmel.com/devices/SAM7X512.aspx?tab=documents
for this document:
"Using Open Source Tools for AT91SAM7 Cross Development" .
This application note provides a guide for using open source tools such
as Cygwin, GNU/GCC ARM Compiler, Eclipse IDE, Zylin CDT and OpenOCD for
low-cost development of AT91SAM7 applications, and can be used for any
other ARM micro (download the *.zip package marked as CD).
MacLyon
Thanks for replying. I read the document. It's fine with Windows. The
same I need to do in UBUNTU. (viz. creating code, compiling, flashing to
the target- ARM Controller, debugging). Any Suggestions??
Thanks
Yes, you may follow the same way:
a) a GCC suite - try CodeSourcery Lite for Linux;
b) Install Eclipse (Juno) CDT package;
c) look for OpenOCD for debugging or another debugger server
d) In Eclipse add this plug-in: http://gnuarm.sourceforge.net for
managed make projects (this means you will not be forced to write
makefiles since the plugin manage that instead of you).
e) do not install Zylin since almost all is included in CDT, you will
need to add only a small hardware debugger plugin - I will tell you
about that tomorrow, since the link is on another computer.
f) another plugin for reading internal registers - also tomorrow.
MacLyon
