Forum: FPGA, VHDL & Verilog VHDL simulation waveform problems
Author: Rousseau (Guest)
Hello everyone, this is my first post here.
Thanks in advance for reading my problem.
Well, I have to create a vhdl code for a 2bit counter, which receives
8bits (where only 3 of them are '1'), and adds 1 to the counter for
every '1' inside those 8bits
I created another signal, "conta", and assigned the variable count to it
inside the process, and so assigned "conta" to the output "contador"
outside the process
Now the "contador" isn't adding when A(i) <= '1'.
I guess there may be a problem the way I attached the signals and
variable inside/outside the process.
Maybe the code isn't proper for what I want, cause I'm a beginner trying
to learn by myself.
If my question is too basic, I would appreciate a link where I could
understand it thoroughly. I got to send a project next friday.
Right now the code is like:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity contador_acertos is
port (clock, reset, enable : in std_logic;
      acertos : in std_logic_vector(7 downto 0);
      contador : out std_logic_vector(1 downto 0)
end contador_acertos;
architecture behavior_contagem of contador_acertos is
signal A : std_logic_vector(7 downto 0);
signal conta : std_logic_vector(1 downto 0);
begin
A <= acertos;
process (clock, acertos, enable, reset)
variable count : std_logic_vector(1 downto 0);
begin
  if (reset = '1') then
  count := "00";
    elsif (clock'event and clock = '1') then
    if (enable <= '1') then
      count := "00";
      oito : for i in 7 downto 0 loop
      if (A(i) <= '1') then
      count := count + 1;
      end if;
      end loop oito;
end if;
end if;
conta <= count;
end process;
contador <= conta;
end behavior_contagem;
This means: one element from the vector A is a std_logic. And if this
elements value is less or equal '1', then increment count.
And now answer the questions: what would you expect from that operation?
Is a operation less-equal defined for a single std_logic element at
all?
> and adds 1 to the counter for every '1' inside those 8bits
I would try it this way:
  if (A(i) = '1') then
    count := count + 1;
  end if;
  • [vhdl]VHDL code[/vhdl]
