Forum: ARM programming with GCC/GNU tools Eclipse .elf files
Author: Juan Peres (Company: none) (jakinto)
I am totally new on this. I set up eclipse and Yagarto
(arm-none-eabi-gcc-4.6.2) but when I build my programs I don't get a
.elf file generated.
I also get the below error:
**** Build of configuration Default for project asasa ****
make all
arm-eabi-gcc -mlong-calls -ffunction-sections -Wall -fshort-enums -g
-I../at91lib/include -I. -I./ -Dat91sam7s256 -c -o obj/main.o main.c
process_begin: CreateProcess(NULL, arm-eabi-gcc -mlong-calls
-ffunction-sections -Wall -fshort-enums -g -I../at91lib/include -I. -I./
-Dat91sam7s256 -c -o obj/main.o main.c, ...) failed.
make (e=2): The system cannot find the file specified.
make: *** [obj/main.o] Error 2
Could it be a mistake in the Make file?
By the way my target is a AT91SAM7S256.
Thanks in advance for your help.
Author: Turbo J (Guest)
You mistyped the command for gcc:
> make all
> arm-eabi-gcc -mlong-calls [...]
It must be "arm-none-eabi-gcc" in your case.
Hi Turbo J,
Thanks for your answer.
I fixed it.
But now I am getting a second error:
make all
arm-none-eabi-gcc -mlong-calls -ffunction-sections -Wall -fshort-enums
-g  -I../at91lib/include -I. -I./ -Dat91sam7s256 -c -o obj/main.o main.c
main.c: In function 'main':
main.c:34:2: warning: implicit declaration of function 'printf'
[-Wimplicit-function-declaration]
main.c:34:2: warning: incompatible implicit declaration of built-in
function 'printf' [enabled by default]
arm-none-eabi-gcc -g  -nostartfiles -Wl,--gc-sections -L../at91lib/lib
-T"../at91lib/lib/sram.lds" ../at91lib/lib/crt0.o -lmachdep -o
bin/sram.elf obj/*.o -lboardlib -lbasicIO
c:/embedded_software/yagarto/bin/../lib/gcc/arm-none-eabi/4.6.2/../../..
/../arm-none-eabi/bin/ld.exe:  error: Source object
../at91lib/lib\libboardlib.a(Button-lib.o) has EABI version 0, but
target bin/sram.elf has EABI version 5
/../arm-none-eabi/bin/ld.exe:  failed to merge target specific data of
file ../at91lib/lib\libboardlib.a(Button-lib.o)
../at91lib/lib\libboardlib.a(OLED-lib.o) has EABI version 0, but target
file ../at91lib/lib\libboardlib.a(OLED-lib.o)
../at91lib/lib\libboardlib.a(SPI-lib.o) has EABI version 0, but target
file ../at91lib/lib\libboardlib.a(SPI-lib.o)
../at91lib/lib\libboardlib.a(stdio.o) has EABI version 0, but target
file ../at91lib/lib\libboardlib.a(stdio.o)
make: *** [sram] Error 1
Any clues what it could be?
Author: Sean Zhang (Guest)
Hi, Juan
I met some similar errors as your second one when I try to generate my
elf file.
Have you solved the problem?
Thanks!
Author: Oliver (Guest)
You are using the wrong libraries. The libs the linker is complainig
about are compiled with an eabi-Version of the Compiler, your are using
a none-eabi version. This does not go togehter. Try to find the
none-eabi versions of the libs, or re-compile them with your compiler.
Oliver
