1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.STD_LOGIC_ARITH.ALL;
4 | use IEEE.STD_LOGIC_UNSIGNED.ALL;
5 |
6 | ENTITY buzzer IS
7 | PORT (
8 | clk : IN std_logic;
9 | rst : IN std_logic;
10 | out_bit : OUT std_logic);
11 | END buzzer;
12 |
13 | ARCHITECTURE arch OF buzzer IS
14 |
15 |
16 | SIGNAL clk_div1 : std_logic_vector(3 DOWNTO 0);
17 | SIGNAL clk_div2 : std_logic_vector(12 DOWNTO 0);
18 | SIGNAL cnt : std_logic_vector(21 DOWNTO 0);
19 | SIGNAL state : std_logic_vector(2 DOWNTO 0);
20 | CONSTANT duo : std_logic_vector(12 DOWNTO 0) :="0111011101110";
21 | CONSTANT lai : std_logic_vector(12 DOWNTO 0) := "0110101001101";
22 | CONSTANT mi : std_logic_vector(12 DOWNTO 0) := "0101111011010";
23 | CONSTANT fa : std_logic_vector(12 DOWNTO 0) := "0101100110001";
24 | CONSTANT suo : std_logic_vector(12 DOWNTO 0) := "0100111110111";
25 | CONSTANT la : std_logic_vector(12 DOWNTO 0) := "0100011100001";
26 | CONSTANT xi : std_logic_vector(12 DOWNTO 0) := "0011111101000";
27 | CONSTANT duo1 : std_logic_vector(12 DOWNTO 0) := "0011101110111";
28 | SIGNAL out_bit_tmp :std_logic;
29 |
30 | BEGIN
31 | out_bit<=out_bit_tmp;
32 | PROCESS(clk,rst)
33 | BEGIN
34 | IF (NOT rst = '1') THEN
35 | clk_div1 <= "0000";
36 | ELSif(clk'event and clk='1')then
37 | IF (clk_div1 /= "1100") THEN
38 | clk_div1 <= clk_div1 + "0001";
39 | ELSE
40 | clk_div1 <= "0000";
41 | END IF;
42 | END IF;
43 | END PROCESS;
44 |
45 | PROCESS(clk,rst)
46 | BEGIN
47 |
48 | IF (NOT rst = '1') THEN
49 | clk_div2 <= "0000000000000";
50 | state <= "000";
51 | cnt <= "0000000000000000000000";
52 | out_bit_tmp <= '0';
53 | ELSif(clk'event and clk='1')then
54 | IF (clk_div1 = "1001") THEN
55 | CASE state IS
56 | WHEN "000" =>
57 | cnt <= cnt + "0000000000000000000001";
58 | IF (cnt = "1111111111111111111111") THEN
59 | state <= "001";
60 | END IF;
61 | IF (clk_div2 /= duo) THEN
62 | clk_div2 <= clk_div2 + "0000000000001";
63 | ELSE
64 | clk_div2 <= "0000000000000";
65 | out_bit_tmp <= NOT out_bit_tmp;
66 | END IF;
67 | WHEN "001" =>
68 | cnt <= cnt + "0000000000000000000001";
69 | IF (cnt = "1111111111111111111111") THEN
70 | state <= "010";
71 | END IF;
72 | IF (clk_div2 /=lai) THEN
73 | clk_div2 <= clk_div2 + "0000000000001";
74 | ELSE
75 | clk_div2 <= "0000000000000";
76 | out_bit_tmp <= NOT out_bit_tmp;
77 | END IF;
78 | WHEN "010" =>
79 | cnt <= cnt + "0000000000000000000001";
80 | IF (cnt = "1111111111111111111111") THEN
81 | state <= "011";
82 | END IF;
83 | IF (clk_div2 /=mi) THEN
84 | clk_div2 <= clk_div2 + "0000000000001";
85 | ELSE
86 | clk_div2 <= "0000000000000";
87 | out_bit_tmp <= NOT out_bit_tmp;
88 | END IF;
89 | WHEN "011" =>
90 | cnt <= cnt + "0000000000000000000001";
91 | IF (cnt = "1111111111111111111111") THEN
92 | state <= "100";
93 | END IF;
94 | IF (clk_div2 /=fa) THEN
95 | clk_div2 <= clk_div2 + "0000000000001";
96 | ELSE
97 | clk_div2 <= "0000000000000";
98 | out_bit_tmp <= NOT out_bit_tmp;
99 | END IF;
100 | WHEN "100" =>
101 | cnt <= cnt + "0000000000000000000001";
102 | IF (cnt = "1111111111111111111111") THEN
103 | state <= "101";
104 | END IF;
105 | IF (clk_div2 /=suo) THEN
106 | clk_div2 <= clk_div2 + "0000000000001";
107 | ELSE
108 | clk_div2 <= "0000000000000";
109 | out_bit_tmp <= NOT out_bit_tmp;
110 | END IF;
111 | WHEN "101" =>
112 | cnt <= cnt + "0000000000000000000001";
113 | IF (cnt = "1111111111111111111111") THEN
114 | state <= "110";
115 | END IF;
116 | IF (clk_div2 /= la) THEN
117 | clk_div2 <= clk_div2 + "0000000000001";
118 | ELSE
119 | clk_div2 <= "0000000000000";
120 | out_bit_tmp <= NOT out_bit_tmp;
121 | END IF;
122 | WHEN "110" =>
123 | cnt <= cnt + "0000000000000000000001";
124 | IF (cnt = "1111111111111111111111") THEN
125 | state <= "111";
126 | END IF;
127 | IF (clk_div2 /= xi) THEN
128 | clk_div2 <= clk_div2 + "0000000000001";
129 | ELSE
130 | clk_div2 <= "0000000000000";
131 | out_bit_tmp <= NOT out_bit_tmp;
132 | END IF;
133 | WHEN "111" =>
134 | cnt <= cnt + "0000000000000000000001";
135 | IF (cnt = "1111111111111111111111") THEN
136 | state <= "000";
137 | END IF;
138 | IF (clk_div2 /= duo1) THEN
139 | clk_div2 <= clk_div2 + "0000000000001";
140 | ELSE
141 | clk_div2 <= "0000000000000";
142 | out_bit_tmp <= NOT out_bit_tmp;
143 | END IF;
144 | WHEN OTHERS =>
145 | NULL;
146 |
147 | END CASE;
148 | END IF;
149 | END IF;
150 | END PROCESS;
151 |
152 | END arch;
