Incrementing/ Decrementing counter does not work
OP #2633901
I have a program that I am working on that decrements every half second
and increments every minute , I don't know how to do the clock dividers
so I am just working on the increase/ decrease of the value and all it
does it stay at the initial value and doesn't change at all , can
someone tell me what I am doing wrong
I commented out every counter except one to test it alone, If u need
more details feel free to ask
Architecture logic of Coolertemp is
  signal cooler: std_logic_vector (6 downto 0);
  begin
  process (t_set, c_temp, d,cooler)
begin
  cooler <= c_temp;
  if(d='0')then
    -- cooler <= cooler + "0000001"; --per two minutes (120s)
      if(c_temp>t_set) then
        c <= '1';
      cooler <= cooler - 1;  --per .5s
    end if;
   -- if (t_set = cooler + "0000001") then
       -- c <= '0';
 -- end if;
end if;
 -- if (d='1') then
   -- c <= '1';
   -- cooler<=cooler+ "0000010" ; --per minute (60s)
--end if;
end process;
Moderator (Company: Titel) #2633941
cooler <= cooler - 1;  -- per .5s
Do you expect the synthesizer to interpret your comments?
Let me say: thats a stupid code that will never work, but you already
found the actual problem:
But you ended up in the wrong direction:
PittyJ already gave a hint: every time (at least all the times > 10ns)
on a FPGA is based on a counter. So you must implement a counter, that
counts to  half a second. And with that counter you can increase you
cooler-value...
That here:
is not a counter, because there is no clock involved! Its just a very
unuseful and unwanted thing called "combinational loop" or
"combinatorial loop" (try these two phrases with google).
OP #2634788
  begin
  process (t_set, c_temp, d,cooler,clk)
begin
  cooler <= c_temp;
  if(d='0')then
      if(c_temp>t_set and clk' event and clk = '1') then
        c <= '1';
    end if;
end
Moderator (Company: Titel) #2638139
This is a EXTREMELY UNUSUAL description of a clock enable. Have a look
at all the other VHDL code around the world. Doing it the same way
will look more like this:
process (clk) begin
  if rising_edge(clk) then
     if(d='0' and cooler >t_set) then
        c <= '1';
     end if;
  end if;
end process;
> I have a clock sorry to not include it even with clock it repeats
> same number over and over
And how does that look like? Do you do a simulation (recommended) or do
you test it on hardware (unusual).
A question of your own? This thread is over 14 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
