Hello to all, I am writing a VHDL code in ISE 9.2, using Modelsim PE 10 Student Edition for simulation. I want to use the sll function in order to rotate a std_logic_vector. When I synthesize the following code with ISE I do not get any errors. But when I am trying to simulate my program using Modelsim, I get only "U" signals. Could somebody tell me what I am doing wrong? Thanks in advance library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; --use IEEE.numeric_std.ALL; entity shifter is Port ( Bus_B : in STD_LOGIC_VECTOR (31 downto 0); shamt_in : in STD_LOGIC_VECTOR (4 downto 0); shift_out : out STD_LOGIC_VECTOR (31 downto 0)); end shifter; architecture Behavioral of shifter is signal B_32 : bit_vector(31 downto 0); signal temp : std_logic_vector(31 downto 0); begin process ( Bus_B, shamt_in) begin B_32 <= to_bitvector(Bus_B) sll conv_integer(shamt_in); temp <= to_stdlogicvector(B_32); end process; shift_out <= temp; end Behavioral;
> I want to use the sll function in order to rotate a std_logic_vector. The sll performs a shift operation, not a rotate operation... > But when I am trying to simulate my program using Modelsim, > I get only "U" signals. How does your testbench look like? Can you post it?
You have right. Thanks a lot for your response. I think that I have found my problem. I typed this process in my test bench tb : PROCESS BEGIN -- Wait 100 ns for global reset to finish wait for 100 ns; shamt_in<="00001"; Bus_B<=X"111111110"; wait; -- will wait forever END PROCESS; But I have made mismatch of the amount of bits in the HEX number. I should have typed Bus_B<=X"11111110"; The strange thing is that while I was running Modelsim I didn't get any warnings or errors. But now that I have restarted Modelsim and rerun my project I got the warning message, so I managed to fix the problem. Do you know why that happened? Thanks a lot again for your response
