Forum: ARM programming with GCC/GNU tools Yagarto & math.h
Author: artjom7111 qwe (Company: Noname) (artjom7111)
Hi.
I write programs for LPC Cortex-M0.
I need to use the cos and sqrt functions from math.
Program:
#include <math.h>
volatile float DeltaX=50, DeltaY=120, Angle=3.14/4;
volatile float Delta;
volatile unsigned char DistanceFlag;
void Func() {
    float dx=DeltaX, dy=DeltaY, angle=Angle, distance_delta;
    dx=dx*cos(angle);
    dx=dx*angle*3.14;
    distance_delta=dx*dx+dy*dy;
    distance_delta=sqrt(distance_delta);
    if (distance_delta>100)
      DistanceFlag=1;
    Delta=distance_delta;
The size of the program increased on>~10kB. Optimization: -O3 or -Os.
How I can reduse code size?
(For this functions normal size must by 2-3kB).
Author: Krapao (Guest)
Error: no matching {
OK.
On AVR-GCC 4.7.0 (i have no Yagarto installed):
.text (Code) size is 1462 Bytes (with minimal main()); .data size is 12
Bytes and .bss is 5 Bytes
size of elf file is 18471 Bytes (with debug symbols, not stripped)
size of hex file is 4170 Bytes
Analyze the output of the toolchain esp. the *.lss and *.map files.
Copy-paste error...
Good result.
What options were used?
Attention: AVR-GCC
gcc version 4.7.0 20120217 - by SRMeister (GCC)
COLLECT_GCC_OPTIONS='-mmcu=atmega16' '-I' '.' '-v' '-gdwarf-2' '-Os' '-funsigned-char' '-funsigned-bitfields' '-fpack-struct' '-fshort-enums' '-Wall' '-Wstrict-prototypes' '-std=gnu99' '-D' 'F_OSC=3686400' '-MD' '-MP' '-MF' '.dep/main.elf.d' '-o' 'main.elf'
I think that the result should be better on ARM.
I have enough single accuracy(float).
