Forum: ARM programming with GCC/GNU tools Yagarto/Eclipse Error
von Mini Papatt (Guest)
hi,
When i tried to build my project an error occurs
"C:\Eclipseworkspace\test2/startup.s:89: multiple definition of
`_start'", i can't solve this error.
Any suggestion?
Thank you in advance, and i apologize my english isn't great.
Best regards.
Mini
My error :
"  **** Build of configuration Default for project test2 ****
make all
-------- begin --------
arm-none-eabi-gcc (GCC) 4.6.2
Copyright (C) 2011 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
arm-none-eabi-gcc -g -Os -std=gnu89 -TSTR91x-ROM.ld -I . -I ./STCode -I
../../Common/drivers/ST/STR91xFWLib/v2.0/inc -D STR91X_GCC
-mcpu=arm966e-s  startup.s
C:\DOCUME~1\ACM\LOCALS~1\Temp\cc8JRMv2.o: In function `_start':
C:\Eclipseworkspace\test2/startup.s:89: multiple definition of `_start'
c:/program
files/yagarto/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-ea
bi/lib/crt0.o:C:\msys\1.0\home\yagarto\newlib-build\arm-none-eabi\libglo
ss\arm/../../../../newlib-1.19.0/libgloss/arm/crt0.S:83:  first defined
here
C:\DOCUME~1\ACM\LOCALS~1\Temp\cc8JRMv2.o: In function `skip_initialise':
C:\Eclipseworkspace\test2/startup.s:205: undefined reference to `main'
c:/program
bi/lib/crt0.o:  In function `start':
(.text+0xe0): undefined reference to `main'
c:/program
bi/lib\libg.a(lib_a-exit.o):  In function `exit':
C:\msys\1.0\home\yagarto\newlib-build\arm-none-eabi\newlib\libc\stdlib/.
./../../../../newlib-1.19.0/newlib/libc/stdlib/exit.c:65:  undefined
reference to `_exit'
make: *** [test2.axf] Error 1  "
von mthomas (Guest)
You are using your own startup-code which conflicts with the default
startup-code, check the -nostartfiles option in the GNU manuals or
search for example makefiles from which you could copy the options into
the Eclipse dialogs.
