Forum: ARM programming with GCC/GNU tools Accessing consecutively named arrays in C
Author: asker (Guest)
This may be a long shot, but anyway...
Say I have lots of arrays named list1[], list2[], list3[], etc.
I want a while() loop where I do something like this:
while(1)
   afunction(listX);
....where X is incremented each time.
In case you wonder why I want to do this, I'm saving C arrays from
Wireshark to feed into C code for testing and the arrays it generates
have incrementing numbers.  Typing in all these array names manually is
tiring.
Author: Mark Brandis (markbrandis)
You could use a two-dimensional array, like so:
#include <stdio.h>
#define LIST_ELEM_MAX 4
#define NO_OF_LIST    3
int main()
  unsigned int i, j;
  unsigned int lists[NO_OF_LIST][LIST_ELEM_MAX] = { { 1,  2,  3,  4 },
                                                    { 2,  4,  6,  8 },
                                                    { 5, 10, 15, 20 } };
  for (i=0; i < NO_OF_LIST; i++)
    for (j=0; j < LIST_ELEM_MAX; j++)
      printf("Element %d of list %d: %d\n", j, i, lists[i][j]);
    printf("\n");
  return 0;
Thanks for the reply, but that still means I have to change dozens or
maybe hundreds of arrays that I simply cut and paste out of Wireshark.
If I could put some syntax around the entire block of arrays without
having to change the syntax of each one, that would be better.
Author: gcc-help@gcc.gnu.org (Guest)
You can do it like so:
extern type_t list1[];
extern type_t list2[];
extern type_t list3[];
type_t *lists[] =
    list1,
    list2,
    list3
extern void do_list (type_t*);
void do_lists (void)
    size_t l;
    for (l = 0; l < sizeof (lists) / sizeof (*lists); l++)
        do_list (lists[l]);
I ended up writing a simple C program to generate a very long list of
function calls with incrementing array names being passed to the
function.  It's messy, but it's the easiest thing I've come up with.
