Forum: µC & Digital Electronics Transistor Tester Compiling Error
Author: Ronnie Tabanao (ronnie_t) Flattr this
I tried compiling the source code for Transistor Tester which I found
here:
http://www.mikrocontroller.net/articles/AVR-Transistortester
And got this error on AVR Studio.
"lcd-routines.c:114: undefined reference to `uart_putc'"
any suggestion will be appreciated..
Author: Boregard (Guest)
which sources?
There are the old ones, which do not have UART at all, and you can
download pre-configured for HW UART or Soft UART. In these the error
should appear earlier than line 114, if at all.
So it does not help, you have to post your source here....
The code I found here:
http://viewvc.coremelt.net/viewvc/avr/semiconducto...
Sorry but I can't attached the code directly here..too long..:(
when I try to compile I got this error:
Build started 8.2.2012 at 14:49:50
avr-gcc -mmcu=atmega8 -Wl,-Map=TransistorTestNew.map main.o lcd-routines.o     -o TransistorTestNew.elf
lcd-routines.o: In function `uart_newline':
D:\Desktop\tester\semiconductor_tester\firmware\default/../../../Latest/Sourcecode/lcd-routines.c:114: undefined reference to `uart_putc'
D:\Desktop\tester\semiconductor_tester\firmware\default/../../../Latest/Sourcecode/lcd-routines.c:115: undefined reference to `uart_putc'
lcd-routines.o: In function `lcd_data':
D:\Desktop\tester\semiconductor_tester\firmware\default/../../../Latest/Sourcecode/lcd-routines.c:32: undefined reference to `uart_putc'
make: *** [TransistorTestNew.elf] Error 1
Build failed with 3 errors and 0 warnings...
Did I missed something?
BR
I do not use and know AVR-Studio...
But it does not use the Makefile, does it?
Because you do not link swuart.o, therefore it does not know the
soft-uart functions.
Regards,
Boregard
I found the MAKEFILE in the folder...
How did you compile yours? and what's the command?
Here is my MAKEFILE:
# Makefile for the project TransistorTestNew
## General Flags
PROJECT = TransistorTestNew
# available languages are: LANG_ENGLISH, LANG_GERMAN, LANG_POLISH, LANG_CZECH, LANG_SLOWAK
UI_LANGUAGE = LANG_ENGLISH
MCU = atmega8
TARGET = TransistorTestNew.elf
CC = avr-gcc
# programmer type
PROGRAMMER=jtag2isp
PORT=usb
CPP = avr-g++
## Options common to compile, link and assembly rules
COMMON = -mmcu=$(MCU)
## Compile options common for all C compilation units.
CFLAGS = $(COMMON)
CFLAGS += -Wall -gdwarf-2 -std=gnu99 -DF_CPU=1000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
CFLAGS += -MD -MP -MT $(*F).o -MF dep/$(@F).d
## Assembly specific flags
ASMFLAGS = $(COMMON)
ASMFLAGS += $(CFLAGS)
ASMFLAGS += -x assembler-with-cpp -Wa,-gdwarf2
## Linker flags
LDFLAGS = $(COMMON)
LDFLAGS +=  -Wl,-Map=TransistorTestNew.map
## Intel Hex file production flags
HEX_FLASH_FLAGS = -R .eeprom -R .fuse -R .lock -R .signature
HEX_EEPROM_FLAGS = -j .eeprom
HEX_EEPROM_FLAGS += --set-section-flags=.eeprom="alloc,load"
HEX_EEPROM_FLAGS += --change-section-lma .eeprom=0 --no-change-warnings
## Objects that must be built in order to link
OBJECTS = main.o lcd-routines.o swuart.o
## Objects explicitly added by the user
LINKONLYOBJECTS =
## Build
all: $(TARGET) TransistorTestNew.hex TransistorTestNew.eep TransistorTestNew.lss size
## Compile
main.o: ./main.c
  $(CC) $(INCLUDES) $(CFLAGS) -D$(UI_LANGUAGE) -c  $<
lcd-routines.o: ./lcd-routines.c
  $(CC) $(INCLUDES) $(CFLAGS) -c  $<
swuart.o: ./swuart.S
##Link
$(TARGET): $(OBJECTS)
   $(CC) $(LDFLAGS) $(OBJECTS) $(LINKONLYOBJECTS) $(LIBDIRS) $(LIBS) -o $(TARGET)
%.hex: $(TARGET)
  avr-objcopy -O ihex $(HEX_FLASH_FLAGS)  $< $@
%.eep: $(TARGET)
  -avr-objcopy $(HEX_EEPROM_FLAGS) -O ihex $< $@ || exit 0
%.lss: $(TARGET)
  avr-objdump -h -S $< > $@
  @echo
  @avr-size -C --mcu=${MCU} ${TARGET}
## Clean target
.PHONY: clean
clean:
  -rm -rf $(OBJECTS) TransistorTestNew.elf dep/* TransistorTestNew.hex TransistorTestNew.eep TransistorTestNew.lss TransistorTestNew.map
## Other dependencies
-include $(shell mkdir dep 2>/dev/null) $(wildcard dep/*)
# device programming
fuses-m8:
  avrdude -c $(PROGRAMMER) -B 10.0 -p m8 -P $(PORT) -F -U lfuse:w:0x01:m -U hfuse:w:0xd9:m
fuses-m48:
  avrdude -c $(PROGRAMMER) -B 10.0 -p m8 -P $(PORT) -F -U lfuse:w:0x42:m -U hfuse:w:0xdc:m
upload:
  avrdude -c $(PROGRAMMER) -B 10.0 -p m8 -P $(PORT) -F -U flash:w:./TransistorTestNew.hex:a \
  -U eeprom:w:./TransistorTestNew.eep:a
I am using Linux, and compile with the avr-gcc toolchain just running
"make all".
But I build it ~ 2 years ago, with the "old" sources without UART.
But according to the Makefile it should still work with "make all" with
the UART. Do not know ho to do that from AVR-Studio, since it does not
run on Linux.
In the Makefile, $(TARGET) depends on $(OBJECTS), and $(OBJECTS) is:
and swuart.o is build with rule:
Regards,
Boregard
Thanks!
I'll update later..:-)
