Forum: ARM programming with GCC/GNU tools make: *** [main.o] Error 1
Author: Vivek Khedekar (Company: Hochschule Karlsruhe) (khedekarvivek)
Hello All,
I have installed the Olimex OCD Development suite and I am getting the
following error. I have installed all the GNU ARM Toolchains.
Yagarto, WinARM, devkitARM and Codesourcery G++
I am still getting this error
**** Build of configuration Debug for project TEST_Prog01 ****
make all
Building file: ../main.c
Invoking: ARM Yagarto Windows GCC C Compiler
arm-none-eabi-gcc -O0 -Wall -Wa,-adhlns="main.o.lst" -c
-fmessage-length=0 -MMD -MP -MF"main.d" -MT"main.d" -mcpu=arm7tdmi-s -g3
-gdwarf-2 -o"main.o" "../main.c"
Kindly advise, what to do. Any help would be appreciated.
Author: Martin Thomas (Guest)
If CS G++/Codebench is also installed please try
cs-make all
Background: maybe the make utility in the systems search path is too old
and incompatible with the current operating system. The CS-Package for
MS-Win hosts comes with a renamed GNU make (cs-make).
If this still does not work please post the output of cs-make --version
, make --version and arm-none-eabi-gcc --version . Also try to remove
the option -fmessage-length=0 from the makefile and also try to call
make with the debug option (cs-make -d all).
webmaster@embdev.netContactAdvertising on EmbDev.net
