Forum: FPGA, VHDL & Verilog any value conversion to 32 bit vector form in vhdl.please help
Author: deepak singh (dksagra)
hi, please help me out...
i have a constant value let A:=9
now i have to convert into digital form...
as we know in digital we can write this 00000000000000000000000000001001
for 32 bit data...
another example i have A:=34
we can write this 00000000000000000000000100010
i want this type of conversion (any number into 32 bit vector form)in
VHDL...
please help me out..its too urgent
Author: Lothar Miller (lkmiller)
Try this:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
signal vector std_logic_vector(31 downto 0);
vector <= std_logic_vector(to_unsigned(34,32)); -- here your value 34 is converted to a 32 bit vector
BTW:
WHERE does this value come from?
And whats your actual problem?
I ask this because I think you asked the wrong question...
thank you so much...
its a long program...
if u want to have a look than i can send...but u understand my logic
right...
but the value of A changes very instant of time...
cant we put directly A inplace of 34
means
vector <= std_logic_vector(to_unsigned(A,32));
like wise...
regards
Author: lkmiller (Guest)
If A is an integer, then yes.
please tell me one thing more...if vector define by you, is variable..
means vector is not signal,its variable..can this convergence is
possible..
regards
What do you mean?
Mark with a x:
[ ] the vector is a variable.
[ ] the input value A is variable, it changes.
Pls post it here as a *.vhdl file attachment.
sending the word file document...
error at the last page...at K_temp
Try it again as *.vhd  or *.vhdl, NOT AS a Microsoft Word *.docx file!
ok...
i am sending the VHD extension file...
thanks for your concern really...
regards
this is zip file, containing everything...
> .docx
> .ise
> .rar
> zip
I cannot help you with those files, because I'm on a smartphone and
can't open either one of them...
So just attach the according *.vhd or *.vhdl file. Is it that difficult?
ok...
this is the file extension .vhd..
please sought out my problem..
problem is at the K_temp
thanks
regards
--error is here-"Operator <INVALID OPERATOR> must have constant operands or first operand must be power of 2
K_temp := "0100000000000000000000000000000000" /A ;
Oooops, a divider. Is this design for a FPGA?
You can simulate a division easily.
But if you want it to run on real hardware, you will get immediately
into trouble, if the divisor isn't a power of 2 (like 2, 4, 8, 16,
32...).
Because if the divisor is a power of 2, then the division is just a
different wiring inside the FPGA. Thats easy, and its done by the
synthesizer on its won.
If the divisor is not a power of 2, then the division gets fairly
complex. You then usually involve a divider-core, plus you will have to
read a manual of at least 20 pages...   :-o
BTW:
Use IEEE .numeric_std .All ;          -- take his one
use IEEE.std_logic_signed.all;        -- or those old osolete ones here
--use IEEE.std_logic_unsigned.all;
use IEEE.std_logic_arith.all;
                                      -- but never all of them together!!!
BTW2:
--* Begin main process . *
Begin
Process ( z_position , reset ) Is
1. There is no "main process". Every process has the very same
proirity, because every process will be synthesized to hardware.
2. The reset is absolutely unnecessary. Because even with reset='1' the
reset-values of x and P will be overwritten immediately in the first two
lines after the "end if;".
BTW3:
x :=
("00000000000000010000000000000000",
"00000000000000010000000000000000");
For better readability try this:
x := (x"00010000",x"00010000");
Or this:
x := (to_signed(65536,32),to_signed(65536,32));
BTW4:
>>> Begin main process
This whole design looks like you are "thinking in software", this will
not lead to a solution for a language that "describes hardware"!
So what to do now?
should i use ipcore?
or one thing is in my mind, tell me is it possible
in K_temp := "0100000000000000000000000000000000" /A ;
first i convert "0100000000000000000000000000000000" into integer
and then convert A into integer..
then divide both bcoz they are in integer now..
after that the resultant of the divison be converted back into signed...
thanks
best regards
> or one thing is in my mind, tell me is it possible ....
Absolutely NO.
Because casting and converting does not change one thing at the fact:
you want to do a division.
You're tricking around and hoping for a hidden way.
That will not work here...
I think you will have to. And: read ALL of the documentation.
thanks a lot....
i would go for ipcore..if i have any problem, i know who can help me
now...
best reagrds....
thanks...
i have implemented the divisor core...
the whole program is working well now...
thanks a ton really..
regards...
Once more (the last time): you do not program a FPGA.
You're writing a hardware description for a FPGA.
You're welcome.
Yes...
now implementing on FPGA...
Regards...
  • [vhdl]VHDL code[/vhdl]
webmaster@embdev.netContactAdvertising on EmbDev.net
