Forum: FPGA, VHDL & Verilog Verilog - FloatingPoint
Author: Krol (Guest)
i want to create a sinus generator in verilog. My problem is that i dont
know how i can connect the output of my module with a floating point
number.
Perhaps someone can give me an small example how to work with floating
point and the output. I tried to use "real" but i dont work as output.
Greetings
Author: Uwe Bonnes (Guest)
You should look at a CORDIC core to generate a Sine Wave.
What is your actual problem?
Do you want to do DDFS?
Then the usual way is to read values out of a sins table.
The other way would be a cordic calculation.
Real numbers are not for snthesis. You can use them for testbenches, but
you will encounter problem with them on real hardware...
Author: Ale (Guest)
I'd suggest you get the datasheet of, for instance, the AD9835. There is
explained how digital synthesis works (in case you do not know). With
that and a very few lines of Verilog (you will need two registers, one
for the phase accumulator and another one for the period of the signal
and a fully populated RAM block, i.e. with a sinus) you get a sinus
generator :).
I got a sinus already using a LUT. But my Problem is that I multiplied
the floating point values with 1000, so that i dont need a point.
Ok, i got an sinus and an amplitude of 1000. But i want an amplitude of
1. And the problem is if i use floating point values my reg dont save
the values.
> the values.
No. The problem is, that you don't understand how numbers are
represented in hardware. Or: do you know what a floating point number
looks like and how difficult it is to handle simple operations like
addition or multiplication on it in hardware?
To keep it short: I don't think you need a floating point number. But
you must rearrange your mind for a different presentation of the
numbers. Lets say: take a 8 bit number in a range from
1000000...00000000...01111111 then you get a decimal value of
-128...0...+127. And then divide this number in your mind by 128 and
you get -1...0...+0.992 for the SAME bit pattern. Think thoroughly about
that!
Never ever take decimal numbers in hardware. A multiplication with 1000
takes a lot of effort. A multiplication with 1024 instead is just a
different wiring and brings zero overhead...  :-o
So it makes no difference in hardware if i implement the sin without
floating points, btw. this way is much easier?
1024 would just be a shift, thats true
> if i implement the sin without floating points
I didn't get this... :-/
But you said, you already have a sine function (via LUT).
So why do you need floating points further on? For scaling the sine?
Just for scaling, because the sine should be in range from -1 ... 1
As I said: -1...+1 isn't possible:
With a 16 bit word you can get  0x1000 ... 0x0000 ... 0x7fff
That is decimal                 -32768 ...      0 ... 32767
If you divide it mentally by     32768
then you get virtually              -1 ...      0 ... +0.999969
So, what do you get out of your sine LUT/algorithm?
  • [vhdl]VHDL code[/vhdl]
