Sensitivity list in VHDL
OP (Company: Private) #2413359
Good morning,
I need some clarifications about sensitivity list in VHDL.
1) Do all input signals for a process have to be listed in the
sensitivity list?
2) Are there differences between two logic circuits synthesized
considering, in the first case, all input signals for a process in
sensitivity list and part of them in second case?
Thank you
Mariano
Guest #2413394
1) for combinatorial logic yes,
   for clocked process only the clock
2) most synthesis tools ignore the sensivity list, giving a warning
Moderator (Company: Titel) #2413418
> sensitivity list?
In common: every signal that requires the simulation to calculate new
values needs to be in the sensitivity list.
No, in the best case you will get a warning or a info about a incomplete
senitvity list. The sensitivity is ONLY for simulation purpose. with a
incomplete or wrong sensitivity list your simulation can look ok, but
the generated hardware is completely different.
Take this:
   signal a,b,clk;
   process (clk) begin
      a <= b;
   end process;
Here your simulation will look as if a is in a kind synchronous to the
clock. In hardware theres only a wire between a and b...  :-o
#2413542
For not having to care about sensitivity lists in VHDL code, I like the
language sensitive feature
VHDL > Update > Sensitivity List (Buffer)
supplied by emacs...
Moderator (Company: Titel) #2413586
> the language sensitive feature
You can also use the corresponding VHDL 2008 all statement:
  process (all) begin
  end process;
A question of your own? This thread is over 15 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
