Forum: FPGA, VHDL & Verilog To many warning
von Maurizio C. (Company: syntronik) (syntronik)
Hello
I am new of that forum, and also new user and VHDL programmer, but all
my
programs working but not optimized
I have one counter 7 digit, I use that for read-out linear, whith zero
point, when I push button, and the zero point arrive, I whant to frozen
the display whith the number in zero point position, but inside the
chip, the counters have to work normaly, when I push for second time the
button,
the number chenge whith real condition of counter.
I using EPM240 Altera, and now working perfect, but I have one kilometer
of warning, the help said
CAUSE: The Quartus  II software has found latches implemented using
non-optimal resources (LUTs with combinational feedback). Timing
Analysis will replace the combinational loop with an equivalent latch.
Timing Analysis will now see this logic as a synchronous endpoint, and
will not analyze the path through the node.
ACTION: Altera recommends that you do not implement latches using
combinational logic. Implement them instead with registers using
asynchronous load and data signals, or remove them from your design.
How I can do, or hiw I have to modify my software??
Thanks in advance
Maurizio
First: VHDL code is NO software. Its a hardware description language.
Just attach your code. Otherwise it makes no sense to give any hints...
Try this page with babelfish or google translator (from German):
http://www.lothar-miller.de/s9y/categories/36-Kombinatorische-Schleife
Yes for you is not sofware, I know that, is hardware descrption, but
it's like a software, where you write instructions like all others
software, and that instructions convert yours descriptions in hardware,
for that,
if you have no licence, and you use the quartusII web edition, the
Altera suggest
"By licence software", can please to suggest to Altera, change in
"By licence for hardware description language".
About the file attachment, I think do not need, to see the list, just
whith your answer, means, you are not able to give any hints
Thanks
regards
Maurizio
No, there you can buy the software for translating your hardware
description (maybe in Verilog or VHDL) to a bit stream. This software
you can buy from Altera is also known as "toolchain". You can/do not buy
a license for any hardware description language, because VHDL is a IEEE
standard.
> whith your answer,
You're very self confident...  :-/
Good luck for your further life.
Nice to hear your personal opinion. But for one you can be sure: I would
be able to. I already made most of your mistakes and doubtless much
more. And after that I figured out why.
> Thanks
You are welcome.
