Hi, I have been using the Ersa i-Con soldering station with the X-Tool desoldering tool. I am seeing that the X-Tool enters standby immediately when I pick up the i-Tool, even though the standby time is set to 10 minutes. This is really frustrating, because when desoldering parts on multi-layer PCB's, and especially when working on ground planes, I need to use both the i-Tool and the X-Tool to really heat the location. The i-Tool has a motion sensor, so it can tell the station to switch over, but the X-Tool apparently doesn't have a motion sensor. So when I pick up the X-Tool, I need to press the button on the unit to "activate" the X-Tool to take it out of standby. Other than setting the standby temperature equal to the working temperature, what can I do to resolve this issue? Is there a software upgrade necessary? I hope it can be resolved without a software update, because my unit doesn't support software update.
