can anyone help me in programming ARM7TDMI processor???? im trying to simulate ARM using PROTEUS Simulation tool. i have to read data from input pins, process the data and give results to output pins. is there any tutorial or sample code for programming ARM processor using PROTEUS SIMULATION TOOL. TOOL accepts code in hex or elf format. How can i convert the code written in C in that format? please help!!!!!! vaibhav
You have to use an C Compiler for ARM7TDMI and set the Copmpiler options to output elf or hex. I can Help you in programming an ARM7TDMI -> you should RTFM !
can u help me on : how to interface LCD with the ARM7..... i mean if i want to display something on lcd how should i connect the data bus of ARM7 with the lcd...which recieves serial input......... i am using proteus VSM for simulation...... help me dude....
> can u help me on : Please open an new thread for a new problem. >how to interface LCD with the ARM7..... > i mean if i want to display something on lcd how should i connect the >data bus of ARM7 with the lcd...which recieves serial input......... Not enough information. - LCD module type? Link to datasheet? - LCD controller type? Link to datasheet? - LCD controller integrated on module or extern? - Which "ARM7"? >i am using proteus VSM for simulation...... Does your simulation-tools offer a module which simulates your LCD? If yes, the documentation of this module should help.
i am not able to find any module about the simulation of lcd........... i hv already generated my hex code.... but i am not able to watch any output from my program as ARM7TDMI has its data bus in the form of packed bus......whereas there is no LCD component in proteus VSM which receives signal in the form of bus.... thank u for previous help! hoping 4 more
