Forum: µC & Digital Electronics [hid-custom-rq] add new Request with multiple Byte return
von Tobias G. (kubax)
i'm completely new to v-usb (and only got realy small knowledge to AVR)
I've a Curcuit for USB Generic Hid (including an ISP-Port) and try to
make a Generic HID device, to get the status of a potentiometer.
I managed to get the "hid-custom-rq" example to work and now i'm trying
to add a new request.
The problem is, that i wanted to test multiple byte answer (to report
back the value from the potentiometer) so i added the request id 3
(CUSTOM_RQ_GET_POTI) and set the dataBuffer to the size of 4 and then to
[0] = 0 ; [1] = 1 ; [2] = 1. All works fine i think, but on the client
side, i only get the first byte and the others are random (or zero if i
first clear the buffer)
could anybody give me a hint what i#m doing wrong?
here is the code for the usb device
request.h
/* Name: requests.h
 * Project: custom-class, a basic USB example
 * Author: Christian Starkjohann
 * Creation Date: 2008-04-09
 * Tabsize: 4
 * Copyright: (c) 2008 by OBJECTIVE DEVELOPMENT Software GmbH
 * License: GNU GPL v2 (see License.txt), GNU GPL v3 or proprietary (CommercialLicense.txt)
 * This Revision: $Id: requests.h 692 2008-11-07 15:07:40Z cs $
/* This header is shared between the firmware and the host software. It
 * defines the USB request numbers (and optionally data types) used to
 * communicate between the host and the device.
#ifndef __REQUESTS_H_INCLUDED__
#define __REQUESTS_H_INCLUDED__
#define CUSTOM_RQ_SET_STATUS    1
/* Set the LED status. Control-OUT.
 * The requested status is passed in the "wValue" field of the control
 * transfer. No OUT data is sent. Bit 0 of the low byte of wValue controls
 * the LED.
#define CUSTOM_RQ_GET_STATUS    2
/* Get the current LED status. Control-IN.
 * This control transfer involves a 1 byte data phase where the device sends
 * the current status to the host. The status is in bit 0 of the byte.
30
31
32
 #define CUSTOM_RQ_GET_POTI    3
33
34
35
#endif /* __REQUESTS_H_INCLUDED__ */
main.c
/* Name: main.c
 * Project: hid-custom-rq example
 * Creation Date: 2008-04-07
 * Tabsize: 4
 * This Revision: $Id: main.c 790 2010-05-30 21:00:26Z cs $
This example should run on most AVRs with only little changes. No special
hardware resources except INT0 are used. You may have to change usbconfig.h for
different I/O pins for USB. Please note that USB D+ must be the INT0 pin, or
at least be connected to INT0 as well.
We assume that an LED is connected to port B bit 0. If you connect it to a
different port or bit, change the macros below:
#define LED_PORT_DDR        DDRB
#define LED_PORT_OUTPUT     PORTB
#define LED_BIT             0
#include <avr/io.h>
#include <avr/wdt.h>
#include <avr/interrupt.h>  /* for sei() */
#include <util/delay.h>     /* for _delay_ms() */
#include <avr/pgmspace.h>   /* required by usbdrv.h */
#include "usbdrv.h"
30
#include "oddebug.h"        /* This is also an example for using debug macros */
31
#include "requests.h"       /* The custom request numbers we use */
32
33
34
/* ----------------------------- USB interface ----------------------------- */
35
36
37
PROGMEM char usbHidReportDescriptor[22] = {    /* USB report descriptor */
38
    0x06, 0x00, 0xff,              // USAGE_PAGE (Generic Desktop)
39
    0x09, 0x01,                    // USAGE (Vendor Usage 1)
40
    0xa1, 0x01,                    // COLLECTION (Application)
41
    0x15, 0x00,                    //   LOGICAL_MINIMUM (0)
42
    0x26, 0xff, 0x00,              //   LOGICAL_MAXIMUM (255)
43
    0x75, 0x08,                    //   REPORT_SIZE (8)
44
    0x95, 0x01,                    //   REPORT_COUNT (1)
45
    0x09, 0x00,                    //   USAGE (Undefined)
46
    0xb2, 0x02, 0x01,              //   FEATURE (Data,Var,Abs,Buf)
47
    0xc0                           // END_COLLECTION
48
49
/* The descriptor above is a dummy only, it silences the drivers. The report
50
 * it describes consists of one byte of undefined data.
51
 * We don't transfer our data through HID reports, we use custom requests
52
 * instead.
53
54
55
56
57
usbMsgLen_t usbFunctionSetup(uchar data[8])
58
59
usbRequest_t    *rq = (void *)data;
60
61
    if((rq->bmRequestType & USBRQ_TYPE_MASK) == USBRQ_TYPE_VENDOR){
62
        DBG1(0x50, &rq->bRequest, 1);   /* debug output: print our request */
63
        if(rq->bRequest == CUSTOM_RQ_SET_STATUS){
64
            if(rq->wValue.bytes[0] & 1){    /* set LED */
65
                LED_PORT_OUTPUT |= _BV(LED_BIT);
66
            }else{                          /* clear LED */
67
                LED_PORT_OUTPUT &= ~_BV(LED_BIT);
68
69
        }else if(rq->bRequest == CUSTOM_RQ_GET_STATUS){
70
            static uchar dataBuffer[1];     /* buffer must stay valid when usbFunctionSetup returns */
71
            dataBuffer[0] = ((LED_PORT_OUTPUT & _BV(LED_BIT)) != 0);
72
            usbMsgPtr = dataBuffer;         /* tell the driver which data to return */
73
            return 1;                       /* tell the driver to send 1 byte */
74
        }else if(rq->bRequest == CUSTOM_RQ_GET_POTI) {
75
      static uchar dataBuffer[3];     /* buffer must stay valid when usbFunctionSetup returns */
76
            //dataBuffer[0] = ((LED_PORT_OUTPUT & _BV(LED_BIT)) != 0);
77
78
      dataBuffer[0] = 0;
79
      dataBuffer[1] = 1;
80
      dataBuffer[2] = 1;
81
82
83
84
    }else{
85
        /* calss requests USBRQ_HID_GET_REPORT and USBRQ_HID_SET_REPORT are
86
         * not implemented since we never call them. The operating system
87
         * won't call them either because our descriptor defines no meaning.
88
89
90
    return 0;   /* default for not implemented requests: return no data back to host */
91
92
93
94
95
int __attribute__((noreturn)) main(void)
96
97
uchar   i;
98
99
    wdt_enable(WDTO_1S);
100
    /* Even if you don't use the watchdog, turn it off here. On newer devices,
101
     * the status of the watchdog (on/off, period) is PRESERVED OVER RESET!
102
103
    /* RESET status: all port bits are inputs without pull-up.
104
     * That's the way we need D+ and D-. Therefore we don't need any
105
     * additional hardware initialization.
106
107
    odDebugInit();
108
    DBG1(0x00, 0, 0);       /* debug output: main starts */
109
    usbInit();
110
    usbDeviceDisconnect();  /* enforce re-enumeration, do this while interrupts are disabled! */
111
    i = 0;
112
    while(--i){             /* fake USB disconnect for > 250 ms */
113
        wdt_reset();
114
        _delay_ms(1);
115
116
    usbDeviceConnect();
117
    LED_PORT_DDR |= _BV(LED_BIT);   /* make the LED bit an output */
118
    sei();
119
    DBG1(0x01, 0, 0);       /* debug output: main loop starts */
120
    for(;;){                /* main event loop */
121
#if 0   /* this is a bit too aggressive for a debug output */
122
        DBG2(0x02, 0, 0);   /* debug output: main loop iterates */
123
#endif
124
        wdt_reset();
125
        usbPoll();
126
127
128
129
and here the code for the client.
set_led.cpp
/* Name: set-led.c
 * Creation Date: 2008-04-10
 * Tabsize: 4
 * This Revision: $Id: set-led.c 692 2008-11-07 15:07:40Z cs $
General Description:
This is the host-side driver for the custom-class example device. It searches
the USB for the LEDControl device and sends the requests understood by this
device.
This program must be linked with libusb on Unix and libusb-win32 on Windows.
See http://libusb.sourceforge.net/ or http://libusb-win32.sourceforge.net/
respectively.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
//#include <usb.h>        /* this is libusb */
#include <lusb0_usb.h>
#include "opendevice.h" /* common code moved to separate module */
#include "requests.h"   /* custom request numbers */
#include "usbconfig.h"  /* device's VID/PID and names */
30
31
static void usage(char *name)
32
33
    fprintf(stderr, "usage:\n");
34
    fprintf(stderr, "  %s on ....... turn on LED\n", name);
35
    fprintf(stderr, "  %s off ...... turn off LED\n", name);
36
    fprintf(stderr, "  %s status ... ask current status of LED\n", name);
37
#if ENABLE_TEST
38
    fprintf(stderr, "  %s test ..... run driver reliability test\n", name);
39
#endif /* ENABLE_TEST */
40
41
42
int main(int argc, char **argv)
43
44
usb_dev_handle      *handle = NULL;
45
const unsigned char rawVid[2] = {USB_CFG_VENDOR_ID}, rawPid[2] = {USB_CFG_DEVICE_ID};
46
char                vendor[] = {USB_CFG_VENDOR_NAME, 0}, product[] = {USB_CFG_DEVICE_NAME, 0};
47
char                buffer[4];
48
int                 cnt, vid, pid, isOn;
49
buffer[0] = 0;
50
buffer[1] = 0;
51
buffer[2] = 0;
52
buffer[3] = 0;
53
    usb_init();
54
    if(argc < 2){   /* we need at least one argument */
55
        usage(argv[0]);
56
        exit(1);
57
58
    /* compute VID/PID from usbconfig.h so that there is a central source of information */
59
    vid = rawVid[1] * 256 + rawVid[0];
60
    pid = rawPid[1] * 256 + rawPid[0];
61
    /* The following function is in opendevice.c: */
62
    if(usbOpenDevice(&handle, vid, vendor, pid, product, NULL, NULL, NULL) != 0){
63
        fprintf(stderr, "Could not find USB device \"%s\" with vid=0x%x pid=0x%x\n", product, vid, pid);
64
        exit(1);
65
66
    /* Since we use only control endpoint 0, we don't need to choose a
67
     * configuration and interface. Reading device descriptor and setting a
68
     * configuration and interface is done through endpoint 0 after all.
69
     * However, newer versions of Linux require that we claim an interface
70
     * even for endpoint 0. Enable the following code if your operating system
71
     * needs it: */
72
#if 0
73
    int retries = 1, usbConfiguration = 1, usbInterface = 0;
74
    if(usb_set_configuration(handle, usbConfiguration) && showWarnings){
75
        fprintf(stderr, "Warning: could not set configuration: %s\n", usb_strerror());
76
77
    /* now try to claim the interface and detach the kernel HID driver on
78
     * Linux and other operating systems which support the call. */
79
    while((len = usb_claim_interface(handle, usbInterface)) != 0 && retries-- > 0){
80
#ifdef LIBUSB_HAS_DETACH_KERNEL_DRIVER_NP
81
        if(usb_detach_kernel_driver_np(handle, 0) < 0 && showWarnings){
82
            fprintf(stderr, "Warning: could not detach kernel driver: %s\n", usb_strerror());
83
84
#endif
85
86
#endif
87
88
    //if(strcasecmp(argv[1], "status") == 0){
89
  if(_stricmp(argv[1], "status") == 0){
90
        cnt = usb_control_msg(handle, USB_TYPE_VENDOR | USB_RECIP_DEVICE | USB_ENDPOINT_IN, CUSTOM_RQ_GET_STATUS, 0, 0, buffer, sizeof(buffer), 5000);
91
        if(cnt < 1){
92
            if(cnt < 0){
93
                fprintf(stderr, "USB error: %s\n", usb_strerror());
94
            }else{
95
                fprintf(stderr, "only %d bytes received.\n", cnt);
96
97
        }else{
98
            printf("LED is %s\n", buffer[0] ? "on" : "off");
99
100
  }else if(_stricmp(argv[1], "poti") == 0){
101
        cnt = usb_control_msg(handle, USB_TYPE_VENDOR | USB_RECIP_DEVICE | USB_ENDPOINT_IN, 3, 0, 0, buffer, sizeof(buffer), 5000);
102
        if(cnt < 1){
103
            if(cnt < 0){
104
105
            }else{
106
107
108
        }else{
109
            printf("LED is %d %d %d\n", buffer[0],buffer[1],buffer[2]);
110
111
//    }else if((isOn = (strcasecmp(argv[1], "on") == 0)) || strcasecmp(argv[1], "off") == 0){
112
  }else if((isOn = (_stricmp(argv[1], "on") == 0)) || _stricmp(argv[1], "off") == 0){
113
        cnt = usb_control_msg(handle, USB_TYPE_VENDOR | USB_RECIP_DEVICE | USB_ENDPOINT_OUT, CUSTOM_RQ_SET_STATUS, isOn, 0, buffer, 0, 5000);
114
        if(cnt < 0){
115
116
117
#if ENABLE_TEST
118
    }else if(strcasecmp(argv[1], "test") == 0){
119
        int i;
120
        srandomdev();
121
        for(i = 0; i < 50000; i++){
122
            int value = random() & 0xffff, index = random() & 0xffff;
123
            int rxValue, rxIndex;
124
            if((i+1) % 100 == 0){
125
                fprintf(stderr, "\r%05d", i+1);
126
                fflush(stderr);
127
128
            cnt = usb_control_msg(handle, USB_TYPE_VENDOR | USB_RECIP_DEVICE | USB_ENDPOINT_IN, CUSTOM_RQ_ECHO, value, index, buffer, sizeof(buffer), 5000);
129
            if(cnt < 0){
130
                fprintf(stderr, "\nUSB error in iteration %d: %s\n", i, usb_strerror());
131
                break;
132
            }else if(cnt != 4){
133
                fprintf(stderr, "\nerror in iteration %d: %d bytes received instead of 4\n", i, cnt);
134
                break;
135
136
            rxValue = ((int)buffer[0] & 0xff) | (((int)buffer[1] & 0xff) << 8);
137
            rxIndex = ((int)buffer[2] & 0xff) | (((int)buffer[3] & 0xff) << 8);
138
            if(rxValue != value || rxIndex != index){
139
                fprintf(stderr, "\ndata error in iteration %d:\n", i);
140
                fprintf(stderr, "rxValue = 0x%04x value = 0x%04x\n", rxValue, value);
141
                fprintf(stderr, "rxIndex = 0x%04x index = 0x%04x\n", rxIndex, index);
142
143
144
        fprintf(stderr, "\nTest completed.\n");
145
146
    }else{
147
        usage(argv[0]);
148
        exit(1);
149
150
    usb_close(handle);
151
    return 0;
152
