Forum: FPGA, VHDL & Verilog TEST BENCH HELP FOR TEXT IO
Author: praveen kumar dr (Guest)
fOLLOWING are the errors i'm getting now...
cic.vhd functional code is proper without errors....
but test bench has some errors..
can you pls help now ?
ERROR:HDLCompiler:806 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 139:
Syntax error near "process".
ERROR:HDLCompiler:837 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 145:
Type void does not match with a string literal
ERROR:HDLCompiler:1728 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line
146: Type error near line ; current type line; expected type void
ERROR:HDLCompiler:806 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 147:
Syntax error near "variable".
ERROR:HDLCompiler:620 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 147:
Near std_logic_vector ; type conversion does not match type void
ERROR:HDLCompiler:806 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 148:
Syntax error near "begin".
ERROR:HDLCompiler:62 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 150:
output_tmp is not a variable
ERROR:HDLCompiler:841 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 152:
Expecting type text for <file_out>.
ERROR:HDLCompiler:187 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 152:
Actual file_out of formal f must be a file
ERROR:HDLCompiler:806 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 145:
Syntax error near "file".r "process".
ERROR:HDLCompiler:806 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 154:
Syntax error near end if
This is what i have to do....
Generate the free running clock, reset for one cycle and ce_r (decimated
clock that generates
one clock pulse for every 5 clock cycles). Clock enable (ce) can be tied
to logic 1 so the filter
is always enabled).
3. Testing at 8 MHz passband: In this region, the filter is supposed to
pass the sine wave with
some change on magnitude. Apply an 8 MHz sine wave sampled by 80 MHz.
This means
you need 10 samples, each one applied at a 80 MHz clock and it is
repeating. Read the input
data samples from a file using TEXT IO and apply the input to the
design. Read the output
values from the waveform and draw both of the waveforms on the same
graph.
---------- Post added at 16:56 ---------- Previous post was at 16:51
below are the 10 samples of 8 MHz wave taken at equal sine angles of 36
degrees and normalised...i.e, multiplied by 2^17 (input data width 0:17)
and then converted to signed binary number..
010010110011110010
011110011011110000
011110011011110000
010010110011110010
000000000000000000
101101001100001110
100001100100010000
100001100100010000
101101001100001110
000000000000000000
these inputs should be feed to the cic filter..
Author: Duke Scarring (Guest)
There was an missing "end if".
Duke
  • [vhdl]VHDL code[/vhdl]
