Low-pass-filter after PFC-Stage
Guest #2362648
Hi, Im modelling in LTspice since long time a PFC-stage including a
Boost-Converter, which works in Boundary Conduction Mode. As control
scheme I use Peak Current Control mode.
As Im interested on a reaction of the output voltage on load variations,
I applied a load Jump from 800W to 1000W (at time stamp 33ms). The
problem is, that the controller is not able to stabilize the output
voltage after the load Jump. I always get low frequenz oscillations as
attached. In my model I use ideal switchtes and ideal inductances and
capacitances. The funtionality does work perfectly, but the settings or
the controller gains are not made correctly by myself. And I dont know
where to adjust, to get these ocillations away(or are they in a
acceptable range.
thx in advance for any hint!
greez kuebli
ps.: red course is the output of the integrator (analog), blue course is
the output-voltage, and the step represents the time stamp, where the
load jump occurs
Guest #2364320
Do not use ideal components. A capacitor with no ESR will lead to a zero
(which helps to boost the phase) at a very (or infinit) high frequency.
Model the Capacitor with a realistic ESR of few 100mOhms.
The low frequenzy oscilation ist the result of to low phase margin of
the voltage control loop. Which controller do you use? I think a simple
integrator... The only way to increase phase margin is to decrease to
integrator gain. But this will lead to larger overshoot of the DC-link
voltage. The only way to get rid of this increased loop gain with high
phase boost. A PI-Regulator could do this...
PS:  Need the .asc file for further help
MFG Fralla
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
