Forum: ARM programming with GCC/GNU tools Linking arm-elf and arm-none-eabi
von Carolyn O. (traisen)
Currently we use Cmake with arm-elf-gcc as the compiler.
I wanted to try arm-none-eabi toolchain.
I am trying to understand how to go back and forth between arm-elf-gcc
compile and link and arm-none-eabi-gcc compile and link.
I switched the compiler and everything compiles, but linking I get the
error at the bottom.
I am not clear on the linking. Can anyone tell me how or tell me where
its explained. I have the Yagarto example, but when I tried going in the
other direction by changing the makefile from none-eabi to elf - that
didn't work either. So they must used either a different linker or the
options are so different you have to change more options... I havn't
found documentation on linkers differences. Just eabi is more general.
Thanks... arm-none-eabi link error below
c:/program
files/yagarto/bin/../lib/gcc/arm-none-eabi/4.5.0/../../../../arm-none-ea
bi/bin/ld.exe:  error: Source object
CMakeFiles/forte.dir/core/extevhan.cpp.o has EABI version 5, but target
forte.elf has EABI version 0
c:/program
bi/bin/ld.exe:  failed to merge target specific data of file
von Duke Scarring (Guest)
Maybe you better cleanup the project before changing the compiler. Both
produce different object code which is not linkable together.
Duke
