static initialization does not work with arm-none-eabi
Guest #2278074
• ▲ useful
▼ not useful
Hello, I moved from arm-elf- to arm-none-eabi- and noticed that a static
variable inside a function would not initialize. A piece of code like:
static uint8_t Config[3] = { 0x87, 0x44, 0x00 } ;
would yield Config[] being { 0x00, 0x00, 0x00 }
That worked with arm-elf ... am I doing something wrong ?
Thank you for help or hints.
Pawel.
#2278077
• ▲ useful
▼ not useful
And data not explicitly initialized is not set to 0, I assume.
Those initializations are part of the startup code linked into the
executable. arm-none-eabi usually implies that there is no operating
system provided program loader (which normally does this job) and that
initialized static data is part of the program data segment, to be
copied from ROM to RAM by some startup code which is provided either by
the development environment or has to be provided by you.
The initialization code depends on definitions within the linker script,
so replacing only of them usually fails.
Guest #2278193
• ▲ useful
▼ not useful
The data appears to be initialized with zeros.
Do you mean the arm-none-eabi- compiler does not generate such startup
code while the arm-elf compiler would generate it ?
Shall I write such code myself ?
Moderator #2278326
• ▲ useful
▼ not useful
I don't think the problem is related to EABI or "old ABI". Are both
toolchains based on the same version of the gcc sources? Let the linker
create a map-file and checked the assigend addresses for the array and
the start and end of the .data output-section? If there are still
problems please create a minimal but full example with source-code incl.
startup-code, linker-script, compiler- & linker-options (pref. in a
makefile).
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
