Forum: ARM programming with GCC/GNU tools Debugging disassembly code
von Alan R. (Company: XC Comms Ltd) (rousey)
I am developing a project using Eclipse/OpenOCD/GDB/G++/FreeRTOS. I
posted a topic recently saying that I couldn't resume from a breakpoint.
The debugger remains stuck at the breakpoint.  The only way to proceed
is to either delete the breakpoint or step from it.  This is a very
annoying bug, since if the breakpoint is on a line that interacts with
peripherals (e.g. sending data via a USART) the project hangs if I try
to single-step from it.
I have just discovered another problem that may be related:
Eclipse Help states "To activate the instruction step mode check the
Instruction Stepping Mode option (Instruction Stepping Mode icon) on the
Debug view toolbar. The Debugger switches to the instruction stepping
mode automatically when the Disassembly view has focus."
If I select Instruction Stepping Mode by right-clicking in the Debug
view I can indeed step through disassembly code. However, if I de-select
it then put Disassembly view in focus the debugger still steps through C
code lines.
I suspect that these problems are related.  Any ideas?
von Yoan (Guest)
Maybe I do not understand well your question, but I work with
disassembly window as follow: I only click on the icon "Instruction
stepping mode" then I click the icon "Step into" for each assembly
instruction line. Please note the icon "Instruction stepping mode"
remain selected, you just need to click it again to revert to C stepping
mode.
Regards,
Yoan
Hi
I can do that, but in the past Eclipse automatically switched to
instruction mode if the disassembly window was in focus (i.e. if I
clicked anywhere in the disassembly window so the Disassemby tab became
highlighted).  This is as per the last sentence of the Eclipse help "The
Debugger switches to the instruction stepping mode automatically when
the Disassembly view has focus.".  It no longer does this.
