Forum: Analog Circuits Role of decopling capacitance
Author: Thomas (Guest)
Hi all,
I always see decoupling capacitors connected at the voltage supply line
of uControllers. I basically know that these capacitors eliminate the
noise so that the voltage at the input of the uC is smooth.
My question now is, how does these capacitors work? Sometimes an
additional resistor is connected in parallel. What is the latter for?
What can be the reason that the voltage at the input of the uC gets
noisy and unsmooth?
And why do we never connect the uC directly to the supply but we always
use a voltage regulator between them?
Thanks
Author: Martina (Guest)
They act as an extra reservoir for fast current spikes and they short
circuit the large inductance of the supply voltage wiring. By this,
large loops are avoided.
>Sometimes an additional resistor is connected in parallel.
Not in parallel, but in series. This forms an RC-filter, which is way
more effective than a simple cap, correct dimensioning provided.
>noisy and unsmooth?
It's the micro itself that creates lots of noise on the supply line, by
the internal switchings!
In battery powered applications this often done. If, on the other hand,
a regulator is used then usually to prevent the micro from being
destroyed by a too high supply voltage.
Hey Martina,
Thank you so much for your details!! You helped me out getting a better
insight in the stuff
I appreciate it!
Thomas
