Forum: µC & Digital Electronics SDRAM 16Mx4x4 and MCF5307
von Frank B. (frank13)
Hello everyone,
I just try to connect the MT48LC64M4A2 SDRAM (16 Meg x 4 x 4 banks) to
my 5307.
I want to use 8 Chips (each with 4 bit data bus). How do I have to
connect and initialise it? The coldfire Init-Tool seems to be confused
with this configuration.
It shows the following config:
ColdFire Pin:    A15 A14 A13 A12 A11 A10 A9 A17 A19 A21 A23      A24 A25
A26 A27
SDRAM Pin:       A0  A1  A2  A3  A4  A5  A6 A7  A8  A9  A10(CMD) BA0 BA1
BA2 BA3
But I only have 4 Banks (BA0 and BA1)! I use 11 Bit column adress A0..9
+ A11. Portsize is 32 Bit.
Where is my fault?
Greetings
Frank
von Ale (Guest)
I'd use the data in table 11-29 of the manual. The last two bits of
address are connected to BA0 and BA1. If you look at the example (only 8
columns) and the corresponding table 11-26 you see how A21 and A22 ended
up in BA0 and BA1.
The Toast board (at http://freeio.org/library/toast.html) also uses this
example in the same way.
Ale
Hi!
Thanks! I will try it this way.
Greetings
Frank
Hi everyone,
just another Problem:
I tried it but the A25 to A27 Pins are not driven from the CPU. My
Initcode is:
MCF5307_DRAMC_DCR = MCF5307_DRAMC_DCR_SO | MCF5307_DRAMC_DCR_RTIM_3 |
MCF5307_DRAMC_DCR_RC(0x18);
MCF5307_DRAMC_DACR0 = (0x3800 << 18)              |
                      MCF5307_DRAMC_DACR_CASL_1   |
                      MCF5307_DRAMC_DACR_CBM(0x6) |
                      MCF5307_DRAMC_DACR_PS_32    |
                      MCF5307_DRAMC_DACR_PM_OFF;
MCF5307_DRAMC_DMR0 = MCF5307_DRAMC_DCMR_MASK_256M |
MCF5307_DRAMC_DCMR_V;
MCF5307_DRAMC_DACR0 |= MCF5307_DRAMC_DACR_IP;
* (vuint32 *) 0xe0000000 = 0xcafebabe;
for (i = 0; i < 5; i++)
asm ("nop");
Does anyone have an idea?
Greetings
Frank
