Forum: FPGA, VHDL & Verilog Problems with my Code
von Adrian M. (bananacode)
Hey guys
I've been having problems with my code.
I'm trying to create a FSM with the following modules, each in a
separate source file:
module ClockCounter(
    input clk,
    input rst,
    output clk_en
reg [24:0] clk_count;
always @ (posedge clk, posedge rst)
begin
if (rst) clk_count <= 0;
  else clk_count <= clk_count+'b1;
end
assign clk_en = &clk_count;
endmodule
module OutputLogic(
    input [2:0] S,
    output reg LA, LB, LC, RA, RB, RC
always @ ( * )
begin
LA <= ~S[0] & S[1] & S[2] | S[0] & S[1] & ~S[2] | S[0] & ~S[1] & S[2];
LB <= S[0] & S[1] & ~S[2] | S[0] & ~S[1] & S[2];
LC <= S[0] & ~S[1] & S[2];
RA <= ~S[0] & ~S[1] & S[2] | ~S[0] & S[1] & ~S[2] | S[0] & ~S[1] &
~S[2];
RB <= ~S[0] & S[1] & ~S[2] | S[0] & ~S[1] & ~S[2];
RC <= S[0] & S[1] & ~S[2];
end
endmodule
module StateHoldingRegister(
    input [2:0] SN,
    input CLK,
    output reg [2:0] S
always @ (posedge CLK)
S <= SN;
endmodule
module NextStateLogic(
    input [2:0] S,
    input L,
    input R,
    output reg [2:0] SN
always @ ( * )
begin
SN [0] <= ~S[0] & S[1] | S[1] & ~S[2];
SN [1] <= S[0] & S[1] & S[2] & L & ~R | ~S[0] & S[2];
SN [2] <= ~S[0] & ~S[1] & ~S[2] & ~L & R | ~S[0] & ~S[1] & ~S[2] & L &
~R | S[0] & S[1] & ~S[2];
end
endmodule
I have no idea how to connect them via verilog, so I created a schematic
symbol for each and connected them via a new schematic source file.
However, I get this error:
ERROR:HDLCompilers:91 - "Thunderbird.vf" line 53 Module
'NextStateLogic_MUSER_Thunderbird' does not have a port named 'L'
ERROR:HDLCompilers:91 - "Thunderbird.vf" line 54 Module
'NextStateLogic_MUSER_Thunderbird' does not have a port named 'R'
ERROR:HDLCompilers:91 - "Thunderbird.vf" line 55 Module
'NextStateLogic_MUSER_Thunderbird' does not have a port named 'S'
ERROR:HDLCompilers:91 - "Thunderbird.vf" line 56 Module
'NextStateLogic_MUSER_Thunderbird' does not have a port named 'SN'
My question to you guys is, what's my mistake? How can I connect the
modules through verilog?
Regards
von Na sowas (Guest)
Id do not know about Verilog, but I found the actual problem:
Look how others are doing it. I expect the solution for your problem in
the very first quarter of any Verilog book!
As stupid as it may sound, I've searched the net looking for code and
examples on how to connect, even looked at a digital circuit book, I did
not find it. I'd be very grateful if you could link me to a site which
says how to..
von bko (Guest)
http://www.verilog.renerta.com/source/vrg00027.htm
for example (but I have not done a syntax check)
[verilog]
module connect_them(
    input clk_from_xtal),
    input L_in,
    input R_in,
    output clk_en
wire [2:0] SN_from_other_module;
wire [2:0] S_to_elsewhere);
wire [2:0] SN_to_othermodule;
 StateHoldingRegister  instance_name_1(
    .SN(SN_from_other_module,
   .clk(clk_from_xtal),
   .S(S_to_elsewhere)
NextStateLogic instance_name_2(
    .S(S_to_elsewhere)),
    .L(L_in),
    .R(R_in),
    .SN(SN_to_othermodule)
///.... an so on
[/verilog]
