Forum: µC & Digital Electronics Sensirion SHT71 with PIC18F2550
Author: Marius H. (Guest)
I'm having problems interfacing a Sensirion SHT71 with a PIC18F2550. I
want to measure the humidity and send it via EUSART to the PC, but I get
nothing on the PC side. I've used the EUSART several times so that is
not the problem. I've attached my assemblerlisting and I hope someone
can help me.
Thanks in advance,
Marius
Author: oli (Guest)
You should use a scope an check out the communication step by step.
Get some Debug-Informations too. I guess you are using MPLAB. So check
out the Debug-mode (View->Watch) It's very helpfull.
Btw: The error is hard to tell, if you dont name the problem more
precisely.
Unfortunately I don't have a scope. It seems like there's a problem with
sending a command. On the ACK impulse I can see that the sensor pulls
the DATA line low (line 144), but it doesn't pull it high afterwards
like it's shown in the datasheet.
Author: oli (Guest)
my assembler isn't that good.
maybe it's a timing problem. try to slow the clock down. but it could be
one of many things. you should really use that debugger and check all
signals step by step.
