Forum: ARM programming with GCC/GNU tools inline asm syntax question
Author: Tat Wan (Company: Universiti Sains Malaysia) (tcwan)
I'm trying to use #defines in inline assembly. However, I kept getting
invalid syntax errors.
The following is hardcoded inline assembly:
inline void dbg_breakpoint_arm(void) { asm volatile (".word 0xE127FF7F" /* (BKPT32_INSTR | BKPT32_MANUAL_BKPT) */ ); }
which compiles fine in gcc.
When I write it as follows:
inline void dbg_breakpoint_arm(void) { asm volatile (".word %0" : "=i" (0xE127FF7F) /* (BKPT32_INSTR | BKPT32_MANUAL_BKPT) */ ); }
gcc gives the following errors (or some variant thereof, this may not be
the exact error message for the above statement).
./armdebug/Debugger/debug_stub.h: In function 'dbg_breakpoint_arm':
./armdebug/Debugger/debug_stub.h:162:1: error: lvalue required in asm
statement.
Is there a way for me to use constant #defines as operands for the asm
statement? What is the correct gcc syntax?
TIA
Author: Stefan B. (stefan)
Instead of
try
    :                  /* Output (empty) */
    : "i" (0xE127FF7F) /* (BKPT32_INSTR | BKPT32_MANUAL_BKPT) */
http://www.ibiblio.org/gferg/ldp/GCC-Inline-Assemb...
@Stefan,
Thanks, I'm not familiar with inline assembly, the gcc reference manual
was pretty cryptic and did not provide examples that explained things
clearly (unfortunately I didn't come across the HOWTO before this).
I tried your suggestion, only change was to use the #defines (but it
does not make any difference to the generated output).
                  : "i" /* (0xE127FF7F) */ (BKPT32_INSTR | BKPT32_MANUAL_BKPT)
The assembly output file had:
        .word #-517472385
which results in "Error: bad expression."
If I remove the '#' manually from the assembly file it passes assembly
stage without any syntax errors. It seems like the compiler expects
operands to be passed to instructions (and hence prepends the '#'
symbol) instead of being used as data values?
Author: Stefan B. (Guest)
That is IMHO a puzzler and i found only one strange solution after a
long search and a lot of trials. I'm not sure this solution is suitable
for all arm-gcc versions. Mine is 4.1.1 (WinARM) and this works:
// I assume your defines look like these
#define BKPT32_INSTR        0xE1270000 // BKPT
#define BKPT32_MANUAL_BKPT  0x0000FF7F // Argument of BKPT
int main(void)
  asm volatile (".word %a0" : : "X" (BKPT32_INSTR | BKPT32_MANUAL_BKPT) );
The usage of modifier in %a0 is based on an old gcc manual
http://sunsite.ualberta.ca/Documentation/Gnu/gcc-2...
The c modifier from the same manual doesn't work at all.
ADD: Sorry, i wrote main() instead of inline void
dbg_breakpoint_arm(void). This comes from the tests.
@Stefan,
Thanks! This works in gcc-4.5.1 as well.
T.C.
Author: Andreas B. (Guest)
Why don't you simply use the BKPT instruction provided by the assembler
instead of assembling it yourself?
Also, given that you probably intend to put the function definition in a
header to inline it always, you should make it "static inline".
Otherwise you'll get a "multiple definition" error when linking.
Hmm. I didn't know about the static inline issue. I'll do that.
I'm actually emulating BKPT on ARMv4T which does not support this
instruction.
The hex value has to be tweaked as the actual BKPT instr value 0xE1xxx
does not trigger on ARM7 CPU. I'm using 0xE7xxxx (Undef) which works.
T. C.
