Forum: µC & Digital Electronics CAN communication on STR912FA does not work
Author: student (Guest)
Hello,
I try to build a CAN communication on my Keil Board „MCBSTR9 Version4“
with the microcontroller „STR912FA“. I did not find a CAN Example for
this Board, so I use the „BLINKY.C: Led Flasher for MCB-STR9 Board“
project and try to build the CAN communication on this project.
At first, I tried a self-test with the settings LoopBack and SilentMode.
That worked fine with the code below. But if I want to send or receive a
CAN message to or from another CAN node, it does not work. I get an
continuous error (ErrorCounter reach its maximum value).
With my osci, I can see a received CAN message on the CAN transceiver
and on the Pins 5.0 (CAN TX) and 5.1(CAN RX). When I am sending a
message, I see nothing on the CAN bus.
Thanks
